Clutch pull
My new to me 2013 requires quite a bit of hand strength to pull the clutch lever in. Everything seems to be adjusted and working great on the bike, it's just that that lever is firmer than I'd like. Is this pretty standard for this lever? Being a hydraulic clutch, are there any adjustments that can be made other than changing the reach via the dial on the lever?
Sent from my Pixel 6a using Tapatalk
(02-20-2023, 10:43 AM)mpuhl_imp Wrote: My new to me 2013 requires quite a bit of hand strength to pull the clutch lever in. Everything seems to be adjusted and working great on the bike, it's just that that lever is firmer than I'd like. Is this pretty standard for this lever? Being a hydraulic clutch, are there any adjustments that can be made other than changing the reach via the dial on the lever?
I would look into flushing the clutch and brake fluids (front and back) as the bike is 10 years old. See if that makes any difference for you.
Unfortunately, there is nothing you can do to ease clutch lever pull except getting softer clutch springs, which will raise the likelihood of slipping/burnt clutch.
The 2017 models have a clutch designed to require less hand pressure, but to my knowledge, no one has tried retro-fitting one in an earlier bike.
I was having trouble with my clutch on my '13. I took off the reservoir cap, and the expansion membrane in there was unseated and all wrinkled up. I pulled it out, straightened it, reinstalled it, added about a tablespoon of fluid, and all good. You may have a kink in the line, or some other kind of blockage that doesn't allow the transfer of energy to the master cylinder. Maybe the master cylinder has a leak. Inspect the whole system.
(02-21-2023, 07:47 AM)Charlie Bravo_imp Wrote: I was having trouble with my clutch on my '13. I took off the reservoir cap, and the expansion membrane in there was unseated and all wrinkled up. I pulled it out, straightened it, reinstalled it, added about a tablespoon of fluid, and all good. You may have a kink in the line, or some other kind of blockage that doesn't allow the transfer of energy to the master cylinder. Maybe the master cylinder has a leak. Inspect the whole system.
I concur - a possible issue easily identified. Had that happen once on an '84 CB750SC hydraulic clutch. Anyway, the same remedy.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,314 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,001 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 250 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,576 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 659 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch slave cylinder gasket Maturecheese_imp 3 399 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 874 11-25-2022, 08:47 AM
  Clutch Lever Full Engagement odelegacy_imp 41 2,705 10-28-2022, 09:27 PM
  Clutch replacement advice misterprofessionality 31 2,591 06-11-2022, 05:51 PM
