Replace clutch Lever
Good morning,
Dropped bike yesterday, need to replace clutch lever.
New one ordered
Is it simply a cases of remove holding bolt drop out old lever, replace with new and refit bolt?
Thanks
Yap, but you have to transfer the brass bush # 2
https://www.hondapartshouse.com/oemparts...r-cylinder
Are you OK, Davidjill?
(02-02-2025, 09:07 PM)peterbaron_imp Wrote: Yap, but you have to transfer the brass bush # 2
Thanks for the heads up
(02-02-2025, 09:27 PM)Cormanus_imp Wrote: Are you OK, Davidjill?
Yes all good thanks.
Just got back from 50 plus mile ride, Jill my partner got off bike, I thought I had put side stand down, clearly hadn't as promptly proceeded to drop 250Kgs of bike !
Broke clutch lever, scratched mirror, Handlebar end and LHS Crank cover! Badly bruised my ego but i am sure that will repair itself !
that's a bummer
(02-03-2025, 01:11 AM)The ferret_imp Wrote: that's a bummer
Yes similar to the words i used too........Angry
I’ve done that. Glad you’re ok.
(02-03-2025, 05:49 AM)Cormanus_imp Wrote: I’ve done that. Glad you’re ok.
Thank You Wink
All those parts are readily available and easy to install. But the best news is that you and Jill are fine and will ride another day on your beautiful motorcycle. David
Never like to hear that someone forgot to put the side stand down, but most of us have done it at some point. In my case, twice, both times with an audience. Glad to hear that the damage was minimal and that you just need to replace a lever (and I'm assuming transfer your RLET to the new lever.)
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,204 12-24-2025, 11:14 AM
  Clutch Plates finally going? misterprofessionality 12 1,044 11-22-2024, 07:49 AM
  Replace HISS key UK Davidjill_imp 0 215 08-01-2024, 01:48 AM
Last Post: Davidjill_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 237 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,442 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 621 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 490 02-21-2023, 10:48 AM
  Front brake lever ROCK hard ichiban_imp 37 3,771 02-10-2023, 10:54 PM
  Long shift lever Sam Mac_imp 1 261 02-08-2023, 08:30 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 382 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
