low oil pressure light
Actually what I wrote is. Most of it is right out of the service manual.
ROFL
Who said plagiarism was out of fashion?
Well, it is a simple circuit, but why not use the manual first? Big Grin
Honda's steps are weird though. Personally I'd check the fuses first then do the sensor check.
Why would a bloke use a carefully constructed manual to get it right first time when he knows better and can do it his way and make a mess of it? Huh
Measured the current through the neutral switch; 8 mA with a ( sensitive ) dc clamp meter, just for kicks.
Dave, Beverly & I look forward to seeing you and Debbie tomorrow afternoon.
My wife and I spent a few days in Las Vegas and had a wonderful visit with Jerry and his wife. You meet the nicest people on this forum!
hello.my low oil light does not light on my 2014 Cb1100.
i wired a led light to the switch. that lights when key on, off when bike starts so switch is good. i took tach off wiring all looks good.
on underside of tach there are a couple of screws at the circuit board.
if i undo screws ,is there anything to look out for? i waht to see if it has a bad solder joint to the led.
honda wants $900.. for new gauge assy.
not worth fixing for that.
any ideas would be great.
thank you.
george
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 870 10-09-2023, 07:51 AM
  low oil pressure light kaput norton1974_imp 11 987 03-28-2023, 08:58 AM
  Interesting article on tire pressure the Ferret 9 798 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,287 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 892 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  running light and brake light Ennsync_imp 3 416 01-02-2019, 11:24 PM
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 637 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 422 10-23-2017, 04:51 AM
Last Post: kennyw
  Tire pressure glynb_imp 12 823 09-29-2017, 03:00 AM
  Oil filter failure.... Complete loss of oil pressure x(why)z_imp 49 2,867 09-14-2017, 10:12 PM
Last Post: paulw_imp
