the Ferret
Ahhhhh things are right in the world again.
Are you feeling disturbed? :-/GoldOxide_imp said:Are you feeling disturbed? :-/
Cormanus_imp said:If that question was directed at me, GoldOxide, no. peterbaron is clearly disturbed.![]()
Looks perfect, the Monkey too.mtneers_imp said:Whoever posted to boil them in hot water first deserves a medal! A heckuva lot easier to put on, but they still have a mind of their own.
PB appears to be an expert on RLETs, and this is quite encouraging. Coming around is he, yeah-zz.peterbaron_imp said:Glad to hear you are OK.
I know for sure, RLETs do not like swapping or to be installed as a single. If anything goes wrong with one, a pair of new RLETs has to be installed.... and this is why, in your situation, you were only lucky at 51% rate.
Source: RLET guru
GoldOxide_imp said:Youch. Yeah, we get to here from time-to-time. Glad to learn you are fine and humor intact. Nice to see the lump is undamaged regardless of no engine guards. That is quite swell.
Now for business ...
Source: RLET guru
RLETs likely behave independently of road conditions. I suspect there may have been attempt to warn the owner to avoid the challenge, but ultimately their influence may have not been enough, regardless of left-right old-new pair-replaced or single-replaced polarity. Cormanus: You may have momentarily over-powered their influence. :-/
