TURN SIGNALS
JohnLM_imp Offline
Threads: 2
TURN SIGNALS
Has anybody attempted to change the turn signals to a more streamlined set or anything different from the stock ones ? I took off one of the rear ones to look at mounting points and other factors and its not going to be a walk in the park . The front signal mounts are even more of a challenge with that deep hole you have to deal with !
11-11-2014, 09:58 AM
vfrpaul98_imp Offline
Threads: 15
RE: TURN SIGNALS
(11-11-2014, 09:58 AM)JohnLM_imp Wrote: Has anybody attempted to change the turn signals to a more streamlined set or anything different from the stock ones ? I took off one of the rear ones to look at mounting points and other factors and its not going to be a walk in the park . The front signal mounts are even more of a challenge with that deep hole you have to deal with !
[url=http://s1077.photobucket.com/user/vfrpaul98/media/IMG_0324_zpsdc8f1f89.jpg.html][Image: c2cc12d0d0d473b8341db94800238c4f.jpg][url=http://s1077.photobucket.com/user/vfrpaul98/media/IMG_0254_zpsa5fce9d1.jpg.html][Image: 24199c1a95fa06f9f9fb1205e9a504ec.jpg][url=http://s1077.photobucket.com/user/vfrpaul98/media/IMG_0253_zps20a9fb1b.jpg.html][Image: eb6febeb09cfdfd657429d4fd8f5ec3b.jpg]
11-12-2014, 07:03 AM
JohnLM_imp Offline
Threads: 2
RE: TURN SIGNALS
Those look really nice , how did you get the nut tightened on the front ones ?
11-12-2014, 07:36 AM
Ack-CB11_imp Offline
Threads: 46
RE: TURN SIGNALS
(11-12-2014, 07:36 AM)JohnLM_imp Wrote: Those look really nice , how did you get the nut tightened on the front ones ?
How to section,
http://cb1100forum.com/forum/showthread.php?tid=2715
11-12-2014, 07:46 AM
JohnLM_imp Offline
Threads: 2
RE: TURN SIGNALS
How to section,
How to section,
I've seen that how to . If I was replacing stock signals it would be helpful . Most of the aftermarket signals are mounted differently with a nut , not an allen head bolt . They will be a lot harder to reach up front .
11-12-2014, 08:44 AM
aschem_imp Offline
Threads: 32
RE: TURN SIGNALS
How to section,
How to section,
How to section,
I purchased the Lockhart signals and I ran them thru the headlight bracket holes that hold the headlight bucket. The turn signals are now my headlight bucket bolts and I like the look.
05-17-2015, 04:52 AM
ChipBeck_imp Offline
Threads: 29
RE: TURN SIGNALS
John,
The Lockhart-Phillips aluminum turn signals are really nice, they look stock but are much smaller and trimmer than the stock units. They attach in a completely different way than the Honda signals. The front center hole must be drilled a bit larger and then use wide stainless fender washers both on the inside and outside of the front signal mounting points. The rear signal attach points do not require any drilling but again you will need to sandwich the mounting points between two fender washers to provide a solid, flat, and centered passageway to pass the signal stalk through and then tighten the bolt to secure it. The front is tricky as getting to everything is like building a ship in a bottle but if you work patiently it can be done.
[url=http://s288.photobucket.com/user/chipbeck/media/Sig%201.jpg.html][Image: ffebdf5d96a880d1dee3c8f481b0c2d8.jpg]
[url=http://s288.photobucket.com/user/chipbeck/media/Sig%202.jpg.html][Image: fe51c9607cfc94d5b910977797128974.jpg]
[url=http://s288.photobucket.com/user/chipbeck/media/Lucas2.jpg.html][Image: 1e909707b691916d553eb0db60522b82.jpg]
[url=http://s288.photobucket.com/user/chipbeck/media/Lucas6.jpg.html][Image: 871db45913f9e39e25ecfb3f5f493817.jpg]
These signals use the same bulb as the stock units and are every bit as bright when activated. Many members pull the wiring all the way back to the connector. I prefer to leave the wiring routing alone and I cut and splice the wires using proper connectors. I used a trimmer tail light as well. Cheers.
Chip
05-17-2015, 06:20 AM
Threads: 346
Likes Given: 963
RE: TURN SIGNALS
Popgun, oh Popgun, wherefore art thou?
05-17-2015, 11:18 PM
  LED Turn Signals deuce17EX 23 2,237 03-12-2024, 10:58 AM
  LED turn signals Elipten_imp 32 2,378 01-05-2023, 05:15 PM
Last Post: CptMoustache_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 661 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Turn signals option USA in EU Łukasz_imp 7 665 02-08-2022, 12:18 AM
  Identify these? Turn signals RandyBMC_imp 3 356 11-11-2021, 09:23 PM
  Anyone fitted Rizoma iRide turn signals to CB1100EX? Richard_imp 8 761 05-20-2020, 09:58 PM
Last Post: Richard_imp
  Lockhart Phillips Turn Signals-Lucas Tail Light ChipBeck_imp 43 3,019 04-17-2020, 07:25 AM
Last Post: gman_imp
  RELOCATION OF REAR TURN SIGNALS ART_imp 28 1,882 02-08-2019, 01:50 PM
  Self canceling turn signals Obleo 19 961 04-24-2017, 08:10 PM
Last Post: Tezza_imp
  Replacement turn signals Mikestib1_imp 5 544 11-19-2016, 10:48 AM
Last Post: flynrider
