Anyone fitted Rizoma iRide turn signals to CB1100EX?
Richard_imp Offline
Threads: 5
As I sit here in lockdown, one of the things I've been considering is changing the turn signals/indicators on my CB1100EX.
The factory ones are very large and very orange - which is of course in keeping with the 1970's, but not necessarily the bike's best feature IMO...
[url=https://postimg.cc/s1TQ0sRn][Image: 90bbbac7de0b6c5f6f024c367653c126.jpg]
[url=https://postimg.cc/ppy9w4WP][Image: b6dc14654ac3f1146da647ddc609e89d.jpg]
[url=https://postimg.cc/3d6yY1Nm][Image: 0ffd5879f04d9f62985b2246ed412ced.jpg]
I have been looking at the Rizoma iRide in chrome...
[Image: 96a9403a9fc86c2bb09674fb3de4012c.jpg]
The Rizoma lens is 35mm diameter, compared with the OEM Honda lens at about 65mm so these would look less obtrusive and also have clear lenses and LED lights.
Total cost for all 4 would be about £250 so I'm keen to hear/see any experience before I go any further.
Anyone help me out?
04-04-2020, 01:49 AM
NovaCB1100_imp Offline
Threads: 2
RE: Anyone fitted Rizoma iRide turn signals to CB1100EX?
(04-04-2020, 01:49 AM)Richard_imp Wrote: As I sit here in lockdown, one of the things I've been considering is changing the turn signals/indicators on my CB1100EX.
Anyone help me out?
Hello Richard,
I also did not care for the large stock signals on the CB, so I added the Rizomas - albeit a different model, but I am very satisfied with the fit, finish and illumination. Huge improvement over stock IMHO. Cost was about $200 for all four USD, not including the LED relay kits which weren't too bad; I think maybe $15 USD or so.
04-08-2020, 01:11 AM
Richard_imp Offline
Threads: 5
Anyone help me out?
Hello Richard,
Thanks so much for your reply, and your pictures. I am tempted to buy the Rizomas but a bit concerned about fitting them.
I can see your front signals fit in a different place to mine but my main concern is the rear ones. Were they simple to fit? What about the wiring?
Any more detail would be very welcome.
Thanks again.
04-08-2020, 03:23 AM
Threads: 2
Anyone help me out?
Hello Richard,
Thanks again.
Thanks again.
Not a problem at all, happy to help!
Fitment on the Rizomas was universal, which means I had to be a little creative since there aren't a lot of options to fit them. The have the standard threaded post that the stock ones have, but the wiring is in through the post, versus ran beside it like the OEM units. (You'll see this when you take them off)
To remedy this, I picked up a set of heavier gauge hardware washers with the diameter as close to the post of the Rizomas, and a spacer. The washer is the mounting base and use of the spacer was two fold; one it pushed the signals out slightly, and two it snugged up to the rubber base on the Rizoma nicely. Since the washers and spacer were silver, I painted them black. I painted them separately at first, and then stacked them for the final coat and clear, to "glue" them together for ease of install.
The wiring was pretty simple. I bought the Rizoma Honda turn signal cable kit (EE075H) which plugs and plays right into the Honda harness with no cutting or splicing. I also had to use LED resistors on all four signals (necessary since the OEM signals on mine are not LED - not sure if yours are or not). Note: If you have LEDs stock already, you wont need the resistors.
The back was easy to tuck everything away and zip tie neatly, but the fronts were a little more challenging since the turn signal wiring is inside the headlight bucket so tucking the LED resistors into an already tight space took some patience.
Well worth the effort - as you can see, compared to stock they're much smaller and since they're LED also way brighter.
04-08-2020, 04:43 AM
Richard_imp Offline
Threads: 5
Thanks again. Your install looks very neat.
I will take a closer look at my bike as a next step.
04-08-2020, 06:08 AM
Richard_imp Offline
Threads: 5
Just to update this thread...
I bought a couple of Rizome iRide turn signals and fitted them to the front of my CB...
[url=https://postimg.cc/QF72wc6N][Image: e4f20355e486c16d7d37cce32658d594.jpg]
Fitting was straightforward, although as the Rizoma's are M8 and the stock signals are M6 I needed to ease the hole in the headlamp bracket using a round file. As the bracket on my bike is specific for the screen I was quite happy to do that, knowing I still have the OEM one in storage.
I also tried them on the back of the bike (apologies for the poor picture)...
[url=https://postimg.cc/JyWfLtgN][Image: d465df10ddd9e5dfd1d40e344784ab59.jpg]
Having a pause before I go for the rear ones.
In both front and rear, I wonder if the small size is out of kilter with the other stuff - rear light, horns etc...
04-22-2020, 08:25 PM
treedoc_imp Offline
Threads: 9
I think they look good Richard, prefer them over the stock.
04-23-2020, 04:12 PM
Richard_imp Offline
Threads: 5
(04-23-2020, 04:12 PM)treedoc_imp Wrote: I think they look good Richard, prefer them over the stock.
Thanks. To use an expression from England, they are probably "marmite" (love it or hate it). Having slept on it, I've decided I prefer them and will be doing the rear ones as soon as the supplier has some stock. Rizoma seem to have suspended shipping just now.
When I do the rear signals I am also thinking of changing the rear light and fender - for something smaller and shorter. Researching the options for that right now.
04-23-2020, 07:39 PM
Richard_imp Offline
Threads: 5
Well I finally received the rear indicators from Rizoma - from a dealer in Spain. Very happy with the way these indicators have changed the look of the CB - although I realise it's not to everyone's taste.
Before:
[url=https://postimg.cc/5XWnHrhG][Image: 40ddee22a68eff8e573a743a3409493c.jpg]
After:
[url=https://postimg.cc/HVxp9j51][Image: 9e0e0b7680a24a62739764ad9177580e.jpg]
05-20-2020, 09:58 PM
  2017 OEM CB1100EX/RS Accessory Brochure rdprdp01 0 335 04-16-2025, 02:05 AM
Last Post: rdprdp01
  LED Turn Signals deuce17EX 23 2,395 03-12-2024, 10:58 AM
  LED turn signals Elipten_imp 32 2,534 01-05-2023, 05:15 PM
Last Post: CptMoustache_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 690 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Turn signals option USA in EU Łukasz_imp 7 699 02-08-2022, 12:18 AM
  CRG Bar end mirrors for 2017 CB1100ex Senna02_imp 5 597 01-20-2022, 06:47 AM
  Identify these? Turn signals RandyBMC_imp 3 384 11-11-2021, 09:23 PM
  QD exhaust for CB1100EX twin muffler arata194_imp 2 343 07-11-2021, 09:02 PM
  Rizoma risers on the cb1100 Zee9_imp 20 1,545 05-28-2021, 02:20 PM
Last Post: Zee9_imp
  Lockhart Phillips Turn Signals-Lucas Tail Light ChipBeck_imp 43 3,322 04-17-2020, 07:25 AM
Last Post: gman_imp
