Torque Specs
I thought it might be nice to have a torque spec thread (but without breaking any copyright laws Wink )
So, could some kind soul please provide the torque specs for the bolts indicated? Thanks! I'm pretty happy with the SW crash bars. I used some black enamel on a couple washers and the bare engine surface where that washer used to be, but it's a nice product.
They are pretty straight forward on the specs. It all depends on the size of the bolt, not the location.
My guess would put that at either a 10mm hex or 12mm hex.
10mm Hex bolt and nut is 25 ft lbs
12mm Hex bolt and nut is 40 ft lbs.
10mm Flange bolt and nut is 29 ft lbs.
Front engine bracket nut (4 of them) is 36 lb/ft,it is a 10 mm thread .This is re shop manual.
I installed SW-mo tech. I tried 40 ft/lbs for the 1st of the 4 front 10mm flange and it got stripped easily. So i did a 29 ft/lbs as recommended by another member. I picked up a genuine replacement for the 1 flange bolt and 1 nut for around 9$ from my local Honda dealer. In my own opinion anything more than 35 ft/lbs will cause damage.
  Torque value question Jonnyteabag_imp 9 630 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 597 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 369 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,295 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Spoked wheel run out specs Jfro5687_imp 3 287 04-19-2020, 06:35 AM
Last Post: Jfro5687_imp
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 774 04-13-2020, 05:47 AM
  Torque specs for handle bar clamp to triple clamp itstuantran_imp 8 612 07-11-2019, 10:16 PM
Last Post: itstuantran_imp
  Shock bolt torque HBFL_imp 9 639 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 1,991 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,158 10-25-2018, 02:25 AM
Last Post: HBFL_imp
