Torque specs for handle bar clamp to triple clamp
Need torque specs for lower handle bar clamp, which mounts to the upper triple clamp. Thanks a lot
From the 2013 Service Manual: The four bolts in the top of the mount are tightened to 15 Ft lb (front ones first). For the 'handlebar lower bolts' it says to tighten securely.
What size are they and I can probably find the general torque specs.
Cormanus,
There is no spec listed. In the 13 manual page 12-10 it says to tighten the handlebar lower holder nuts securely.
I’m not sure the general torque table would work here due to the rubber mounting.
Thanks a lot Cormanus. Bolt size 8mm
(07-11-2019, 06:27 PM)Cormanus_imp Wrote: From the 2013 Service Manual: The four bolts in the top of the mount are tightened to 15 Ft lb (front ones first). For the 'handlebar lower bolts' it says to tighten securely.
Be careful.
The nut is actually tightening against metal tube inside the rubber mount, that means:
1. you can not tighten the rubber mounts tighter as they are Smile
2. it's quite easy to over-tight and tear off the bolt or thread (believe me Wink)
And finally -- there are self-locking nuts, so better a bit too loose than too tight.
Thanks popgun
(07-11-2019, 07:29 PM)Lord Popgun_imp Wrote: Cormanus,
Thank you Girt80
(07-11-2019, 08:15 PM)Girts80_imp Wrote: Be careful.
Metric Hex Cap, Plated - Recommended Torque in Ft/Lbs unless Noted
Grade 4.8 Grade 8.8 or 9.8 Grade 10.9 Grade 12.9
Lube Dry Lube Dry Lube Dry Lube Dry
M4 (In/Lbs) 8.5 10.0 20.4 27.6 28.8 38.4 33.6 45.6
M5 (In/Lbs) 15.6 21.6 40.8 54 58.8 78 68.4 91.2
M6 (In/Lbs) 42 54 78 102 114 144 138 150
M8 8.5 11.5 16 20 24 30 28 35
M10 17 21 32 40 47 60 55 70
M12 29 39 55 70 80 140 95 120
M14 47 60 88 110 130 165 150 190
M16 73 92 140 175 200 225 240 300
M18 100 125 195 250 275 350 325 410
M20 140 180 275 350 400 500 460 580
Thank You jimgl3!
This is great info. Thumbs Up
Though I don't think I have ever seen grade 4.8 bolts. Who needs something this soft?
Thank you
(07-11-2019, 08:35 PM)jimgl3_imp Wrote: Metric Hex Cap, Plated - Recommended Torque in Ft/Lbs unless Noted
  Torque value question Jonnyteabag_imp 9 661 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 650 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 421 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,666 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Spoked wheel run out specs Jfro5687_imp 3 314 04-19-2020, 06:35 AM
Last Post: Jfro5687_imp
  2014 cb1100 frame fork stem specs ck1100-smithbros_imp 13 892 04-13-2020, 05:47 AM
  Handle bar replacement/ Finally happened bike backed into or attempt to steal mustang462002_imp 7 458 05-10-2019, 12:00 PM
  Shock bolt torque HBFL_imp 9 716 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,128 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,217 10-25-2018, 02:25 AM
Last Post: HBFL_imp
