Rear turn signals
Hello,
Question: When I start the bike the front turn signals stay on but the rear turn signal are off. I noticed that the rear turn signals only come on when I push the switch to use left/right or emergency lights (then all 4 turn signals blink). Are the rear turn signals supposed to stay on all the time like tail-lights?
Thank you,
SFO
No..only fronts are running lights and blinkers. Rear are blinkers only.
(11-10-2013, 09:57 AM)The ferret_imp Wrote: No..only fronts are running lights and blinkers. Rear are blinkers only.
Thank you sir!
I thought there was something wrong and started to panic Big Grin
I made the same mistake when I swapped out the rear signals for smaller ones. My first inclination was to jump on the forum and ask for help.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,421 08-16-2025, 05:01 PM
Last Post: bflint
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 682 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  removing rear turn signal modmaster_imp 12 914 04-20-2023, 10:17 AM
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 691 05-01-2022, 06:23 AM
  Changing Placement of Rear Turn Signals eddi0_imp 9 685 06-27-2021, 03:57 AM
Last Post: Gordo_imp
  Rear Turn Signal relocation paulw_imp 10 798 03-07-2021, 05:50 AM
  LED turn signals Jeff in OH_imp 18 1,175 11-15-2020, 07:11 AM
Last Post: FLYTYM_imp
  Wiring diagram for turn signals. kmoney_imp 21 1,211 05-06-2019, 03:42 AM
Last Post: domeular_imp
  Turn signals acting crazy Headbanger02_imp 10 674 03-30-2019, 09:58 PM
  Turn Signals/Hazard Lights - Not Blinking/Not Turning on mnm2008_imp 20 1,244 06-24-2018, 02:39 PM
