removing rear turn signal
Where is the connector for the rear turn signal wire? I'm trying to remove it and I don't see where the pin connector is. Can anyone help me out? I don't have the factory service manual yet and a few searches didn't reveal the right information.
modmaster
On mine, 2014 standard, they are under the fuse box, under the tool cubby thing.
Sent from me......
Yup. Take out the storage box and possibly even the battery if you want more room. They (two signals and a tail/stop light connection) are all contained in the giant opaque rubber boot along with that red accessory connector.
Easy peasy.
OK, reviving this briefly, on the fender, under the seat, the rear tail light and turn signal wires are captured by a tack welded "C" shape of metal that is open on one end but sits tight very close to the fender. Do you just pry this open to release the wires or just pull them out and force them back through??
Gently pry.
Sent from an undisclosed location
Thanks. After studying this closely I think I can safely remove them and re-install with the new "C-Bow" system from H&B afterall.....
(04-24-2016, 06:53 AM)DaSwami_imp Wrote: Thanks. After studying this closely I think I can safely remove them and re-install with the new "C-Bow" system from H&B afterall.....
Hi, i am also going to install the c bow carrier. After removing the rear blinkers, did you need to fabricate and extend the blinker cables or was there enough stowed away to be stretched out?.
You have to extend your wires. There is nothing extra. I went with LED aftermarket lights with longer leads. You can see my pics in the link in my signature.
So, how best to "extend" the wires? Sorry, could not find your pics.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,507 08-16-2025, 05:01 PM
Last Post: bflint
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 750 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 540 12-08-2022, 09:24 PM
Last Post: leung_imp
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,882 07-12-2022, 08:04 PM
Last Post: tommymck
  2013 turn signal replacement RF(OEM) casey66_imp 17 1,260 01-15-2022, 01:31 AM
Last Post: Bazbro_imp
  Changing Placement of Rear Turn Signals eddi0_imp 9 724 06-27-2021, 03:57 AM
Last Post: Gordo_imp
  removing both wheels Tom_imp 20 1,634 05-21-2021, 01:07 AM
  Turn Signal Malfunction billyfinchapel_imp 5 554 05-04-2021, 01:51 PM
Last Post: billyfinchapel_imp
  rear signal assembly cj599_imp 14 1,021 03-19-2021, 08:14 AM
Last Post: cj599_imp
  Rear Turn Signal relocation paulw_imp 10 840 03-07-2021, 05:50 AM
