Turn signals acting crazy
When I turn my left blinkers on all 4 front and rear flash, my right blinker works in the off or on the right position, I haven't mess with anything electrical with this bike, oh yeah, it's a 2013 model if it makes any difference, anybody know what my problems is? Thanks
Have you checked your hazard slide switch on the right handlebar ( with the little triangle above it ) ? maybe try switching it several times and see if it works the same every time, i doubt if it is a connection between the left and right channel, if that happened it would work both left and right i think they are all wired separately because of the need to light up the front set all the time, if the right hand switch works as expected you could be the first to report a faulty flasher unit or a faulty indicator switch somehow, those are the only parts that can cause this particular( directional ) fault,did you have any thing connected to the battery that went wrong?
Max, THANK YOU, THANK YOU, THANK YOU, I've had this bike for 5 years, I don't ride it much, but I never knew I had flashers....till now, I knew it had to be something simple, all is well now, again thank you!
Fixed? ( edit ) sorry i replied too soon, very much appreciate your feedback and good luck!Smile
The hazards can be hazardous. Smile
Apparently there aren’t hazards in Australia so Honda didn’t need to fit that extra switch here.
(03-30-2019, 11:27 AM)Cormanus_imp Wrote: Apparently there aren’t hazards in Australia so Honda didn’t need to fit that extra switch here.
Oh wow - interesting? Learned something new!
...just to add to the "learned something new" spice: here in Hungary drivers use hazard lights as a "thank you" or "sorry" note. Bikers use it whenever they do lane splitting or just filtering through. At first it drove me crazy to see someone cutting in and then turning on the hazard lights - my initial thoughts were "OMG, this moron just cut me, and now will stop right there..." Big Grin
Cormanus, I’d guess you don’t have the US DOT there nannyizing everything Smile
No, we have 8 of them!
  Hibeam and hibeam flash button acting up. Jgarciajr40_imp 7 753 04-01-2024, 08:13 AM
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 747 05-01-2022, 06:23 AM
  Changing Placement of Rear Turn Signals eddi0_imp 9 747 06-27-2021, 03:57 AM
Last Post: Gordo_imp
  LED turn signals Jeff in OH_imp 18 1,245 11-15-2020, 07:11 AM
Last Post: FLYTYM_imp
  Bike acting like it’s in neutral when it’s in 1st gear carlenn_imp 29 1,719 08-08-2019, 09:18 PM
  Wiring diagram for turn signals. kmoney_imp 21 1,303 05-06-2019, 03:42 AM
Last Post: domeular_imp
  Turn Signals/Hazard Lights - Not Blinking/Not Turning on mnm2008_imp 20 1,301 06-24-2018, 02:39 PM
  Gap in throttle housing is driving me crazy! x(why)z_imp 19 1,446 06-06-2018, 08:24 PM
Last Post: Blockhead_imp
  Signals flash faster than emergency flashers mattmcuomo@yahoo.com 12 862 02-24-2016, 03:45 AM
  Turn signals at night brougham79_imp 4 360 10-16-2014, 11:45 AM
Last Post: flynrider
