Wire Colors for Signals, Tail Light
I'm in need of some help with wiring replacement aftermarket turn signals and a taillight. Specifically when it comes to the wire colors. This is for a 2014 standard, btw.
I've been searching this forum and other possible sources most of today looking for some kind of reference guide for this, but come up mostly empty. I have the technical/mechanical ability to connect the wiring, but not the electrical knowledge to be sure I'm putting the correct wires together. I'm also a little apprehensive to continue a trial-and-error process, as I think I might've blown a fuse doing that last night. (An annoying little setback.... but, oh well.)
Anyway, If anyone could please help demystify the color codes of the wiring, I would be eternally grateful!
If your replacement turn signals have incandescent bulbs, it should be relatively easy.
As you are sitting on the bike:
Left front is orange/white
Left rear is an orange
Right front is light blue/white
Right rear is light blue
In each case, ground is green
The fronts incorporate a running light that becomes the brighter flashing turn light.
If your new front turn signal has 3 wires, hook up the brighter light's wire.
Taillight is green with yellow for brake, brown for the taillight, with green as ground again.
If you are going to LED turn signals, start here:
http://cb1100forum.com/forum/showthread....rn+signals
This is exactly what I was looking for; Thank you so much!
Can I ask how you found/know that info? Is there a wiring diagram somewhere, or something in the manual I missed?
And, yeah, they are incandescent. So, hopefully not too troublesome.
The service manual has the wiring diagrams in it. Not the owners manual.
Ahh, I see. I'm pretty sure I have a digital version of that I bought a couple years ago sitting around somewhere...
Wiring diagrams - http://cb1100forum.com/forum/showthread.php?tid=13353
(04-27-2022, 08:56 AM)Cormanus_imp Wrote: Wiring diagrams - http://cb1100forum.com/forum/showthread.php?tid=13353
*chef's kiss*
Thanks
Thumbs Up
As it happens, I am considering moving the rear turn signals back to the end of the topbox mount so I get a pair of soft bags onto the CB. I had a pair on before, but they're so far forward that I have to sit on one of the velcro straps. Not too bad, but....
If you’re good at wiring, Charlie Bravo, it’s not to hard a job. If, like me, you’re not, it’s time consuming and tedious. But worth it.
  m-txd/rxd wire (white) ecu to instruments communication deano 28 1,693 01-23-2026, 12:48 PM
  M-TXD/RXD wire is disconnected deano 1 183 01-01-2026, 06:40 AM
  2017 tail light rattle Venteuri_imp 2 376 05-14-2024, 05:55 AM
Last Post: Venteuri_imp
  2017 Tail light housing swap dogclerk_imp 0 202 07-05-2022, 12:31 AM
Last Post: dogclerk_imp
  Tail light install problem iamheero_imp 9 713 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  Changing Placement of Rear Turn Signals eddi0_imp 9 730 06-27-2021, 03:57 AM
Last Post: Gordo_imp
  LED tail light connector shahyaan_imp 10 908 11-28-2020, 09:33 PM
Last Post: shahyaan_imp
  LED turn signals Jeff in OH_imp 18 1,239 11-15-2020, 07:11 AM
Last Post: FLYTYM_imp
  2017 EX Tail light wire channel access TXBikerGuy 8 744 07-26-2020, 06:57 AM
Last Post: TXBikerGuy
  Tail Tidy and Plate Relocation jethrofelix_imp 21 1,682 06-05-2020, 12:03 PM
Last Post: run-tmc_imp
