How to remove rear signals?
Can someone help describe what needs to come off to thread the turn signal wires out? I'm trying to install a Hepco becker C-mount which relocates the turn signals, I read the connectors are behind the battery box, but not sure how to remove black panel shown in picture to thread the wires through? Good rainy day project...maybe.
Expose the battery and unplug the orange and blue connectors. You can feed the wires out from that end.
[Image: 4acf9424a18b41e03fb6f70bd7a742b5.jpg]
[Image: de5db1c3cf4538a359e640f4fd6f439f.jpg]
Thanks how about under the black metal where you see the 3 10mm silver bolt heads, do you disassemble anything there or just "feed" through?
No need to remove those bolts. Just feed it through between the fender and subframe.
Under your fender there are I'll believe 6 nuts/bolts that hold your tail light on. Remove those, then on your tail light there will be 2 Phillips screws and a couple clips how to remove the cover over the wires. Disconnect the bullet connectors for your turn signals. At this point you can remove the nut on the inside of your fender that is on the base of the turn signal. Hope that helps.
Are there any front/rear turn signals that are plug_and_play? I am not very good with rewiring.
(04-03-2014, 01:39 AM)Copiche_imp Wrote: Under your fender there are I'll believe 6 nuts/bolts that hold your tail light on. Remove those, then on your tail light there will be 2 Phillips screws and a couple clips how to remove the cover over the wires. Disconnect the bullet connectors for your turn signals. At this point you can remove the nut on the inside of your fender that is on the base of the turn signal. Hope that helps.
I swapped out my turn signals, US model to Japanese model, and only had to remove the grab bar to remove the nut holding each turn signal stalk in place.
  How to remove O2 sensor CB1100AZ_imp 10 921 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Help - Overfilled Oil, how to remove? saru2011_imp 25 1,846 08-18-2022, 08:31 AM
Last Post: ymtnpoah11_imp
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,414 06-03-2022, 01:16 PM
  How to remove both wheels? RandyBMC_imp 18 1,463 05-10-2022, 11:12 PM
Last Post: Tom_imp
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 744 05-01-2022, 06:23 AM
  Changing Placement of Rear Turn Signals eddi0_imp 9 747 06-27-2021, 03:57 AM
Last Post: Gordo_imp
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,345 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  LED turn signals Jeff in OH_imp 18 1,245 11-15-2020, 07:11 AM
Last Post: FLYTYM_imp
  How to remove turn signal bracket on 2013 model Mtnduc_imp 6 475 10-16-2019, 08:12 AM
  Wiring diagram for turn signals. kmoney_imp 21 1,298 05-06-2019, 03:42 AM
Last Post: domeular_imp
