How to remove turn signal bracket on 2013 model
My son’s friend lightly wrecked his 2013 and I’m putting it back together for him.
How do you remove the bracket holding the front turn signals?
It seems to be inserted into both the upper & lower triples.
Loosen and pull the top triple up?
TIA
Not sure without looking at my bike, but this may help: https://www.partsfish.com/oemparts/a/hon.../headlight
Edit to add: After looking at the diagram some more, I think you may be right as it plugs in to the upper and lower triple. I'll have to look in the service manual tonight unless someone else answers.
Looks very similar to my Nighthawk. Yes, removal was to loosen and raise the upper to pull the assembly out. The challenge was the four rubber cups that go onto the four studs that locate the whole assembly. They like to fall off as you're jostling it into place.
What Gone said. I looked in the service manual and you have to remove (or at least move up) the top bridge. You are going to need a torque wrench to set the stem nut and then check/adjust the bearing pre-load.
Yep, got it all done.
Anybody happen to have the pinch bolts and stem nut torque settings?
Great to read Mtnduc, ... and welcome to the Forum!
Fork top bridge pinch bolts— 17 ft lbs.
Fork bottom bridge pinch bolts— 32 ft lbs.
Steering stem nut— 76 ft lbs.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,492 08-16-2025, 05:01 PM
Last Post: bflint
  How to remove O2 sensor CB1100AZ_imp 10 857 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Cam chain model and relpacement. syncronizator_imp 19 1,636 10-20-2023, 08:45 PM
  Pictures of OEM Rear turn signal mount Houndwheels_imp 8 744 09-12-2023, 10:28 AM
Last Post: Houndwheels_imp
  removing rear turn signal modmaster_imp 12 988 04-20-2023, 10:17 AM
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,142 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 532 12-08-2022, 09:24 PM
Last Post: leung_imp
  Help - Overfilled Oil, how to remove? saru2011_imp 25 1,796 08-18-2022, 08:31 AM
Last Post: ymtnpoah11_imp
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,873 07-12-2022, 08:04 PM
Last Post: tommymck
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,341 06-03-2022, 01:16 PM
