Help - Overfilled Oil, how to remove?
Hi, I overfilled engin oil, and it’s way higher than the upper limit from the inspection window. Can you please let me know how to remove excessive oil? Thanks!
I'd crack open the drain bolt, then retighten when you think you've got enough out.
(09-09-2018, 12:23 PM)LongRanger_imp Wrote: I'd crack open the drain bolt, then retighten when you think you've got enough out.
Thanks, but then the crush washer can’t be reused, right?
No problem re-using the crush washer. Some people don't ever replace them.
Also, unless you REALLY overfilled it (like, and extra quart by mistake), I'd just let it be. Many new bikes, including mine, were overfilled from the factory, and it functions just fine. Save yourself the mess.
(09-09-2018, 12:13 PM)saru2011_imp Wrote: Hi, I overfilled engin oil, and it’s way higher than the upper limit from the inspection window. Can you please let me know how to remove excessive oil? Thanks!
How much oil did you put in it?
It takes 4 quarts to fill, only check level after engine has been run and left sitting a couple minutes.
loosen the oil filter , watch the level drop and tighten back up ?
(09-09-2018, 02:49 PM)max_imp Wrote: loosen the oil filter , watch the level drop and tighten back up ?
Best bet is to go the drain plug route. It's the method with the least amount of cleanup involved, and the most controllable with how much you release.
That's what I did; cracked open the drain plug, let it drip for a while until the level drops to where you want it and tighten it back up.
I've reused the washers many, many times on different bikes and have never had a leak.
Don't be too ham-fisted when you tighten the drain plug. Tight is tight enough. Torque value is 22 ft lbs which is plenty.
Thanks guys. I crack opened the drain plug, a more controllable approach and drain about a quarter qt. Now the level is back to normal within the upper/lower bars.
Thanks again.
  How to remove O2 sensor CB1100AZ_imp 10 857 12-13-2024, 09:57 AM
Last Post: inditx_imp
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,341 06-03-2022, 01:16 PM
  How to remove both wheels? RandyBMC_imp 18 1,393 05-10-2022, 11:12 PM
Last Post: Tom_imp
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,281 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  How to remove turn signal bracket on 2013 model Mtnduc_imp 6 445 10-16-2019, 08:12 AM
  Overfilled oil from dealer Spiderwatts_imp 11 1,184 10-13-2017, 03:17 AM
Last Post: nhawk7504_imp
  Tank, raise or remove? MM300_imp 6 407 06-23-2017, 09:55 PM
Last Post: MM300_imp
  Do I have to remove the rear tire to remove the fender? Nemo_imp 3 336 03-21-2016, 12:11 PM
Last Post: uscgmac_imp
  How to remove bar ends twiin640_imp 4 383 02-23-2015, 07:18 AM
  Remove Seat from 2013 CB11 huxley_imp 9 680 08-19-2014, 01:22 PM
Last Post: gossman_imp
