How to remove both wheels?
I tried looking and didn’t see anything for both wheels at the same time. I have a normal car jack and a motorcycle jack. I need to pull off the wheels, and on my CB750K, the jack can hit both frame rails and I can strap and support it to pull both wheels. Doing a tire change on the 1100 and have to bring both wheels to the shop.
The CB1100 has exhaust in the way of the other side of the frame rail. How are you guys lifting the bike and removing both wheels?
Thanks!
I use the center stand and a jack under the engine. A piece of wood on the jack so no metal on metal.
I do the same with the ST.
(04-06-2022, 08:00 AM)Lord Popgun_imp Wrote: I use the center stand and a jack under the engine. A piece of wood on the jack so no metal on metal.
And you can safely balance it with front and rear wheels removed?
Thanks!
I put the bike on the center stand and a PitBull front stand. Simple as can be.
Thanks!
Thanks!
Works fine for me and other members. Haven’t had any problems and it is steady. I do loosen the axle nuts and remove a front caliper first. I wouldn’t do other maintenance like that though.
That Pit Bull stand mentioned above would be great but I don’t have one.
PitBull stand for the front and one for the rear : worth the investment !
I do the center stand and a rubber pad on my floor jack under the engine.
I would recommend putting the bike on the centerstand, and take the rear wheel off. Then remove the front calipers and loosen the front axle bolt and axle pinch bolts, all before lifting the front end with a jack.
And reassemble in the reverse order.
Centre stand and car jack on the engine bars. My IKEA step as extra insurance. I seem to remember posting this in another thread?
(04-06-2022, 11:01 AM)pekingduck_imp Wrote: I would recommend putting the bike on the centerstand, and take the rear wheel off. Then remove the front calipers and loosen the front axle bolt and axle pinch bolts, all before lifting the front end with a jack.
+1
On my 2014, the hex nut at the end of the Honda oil filter cap wrench fit perfectly into the recess of the front axle. Once the axle bolt was removed, it was super easy to remove the axle using the cap wrench as a hand wheel to spin it out.
  How to remove O2 sensor CB1100AZ_imp 10 881 12-13-2024, 09:57 AM
Last Post: inditx_imp
  CB1100 EX tyres & wheels Ol' RedJ_imp 14 1,139 07-19-2023, 05:04 PM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 638 05-13-2023, 05:43 AM
  Laced wheels ? ashishNJ_imp 3 359 02-08-2023, 01:09 PM
  Help - Overfilled Oil, how to remove? saru2011_imp 25 1,816 08-18-2022, 08:31 AM
Last Post: ymtnpoah11_imp
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,375 06-03-2022, 01:16 PM
  Replacing Wheels - Manual Instructions Ludicrous jasonsargonautalis_imp 12 1,227 12-11-2021, 08:52 AM
Last Post: jimgl3_imp
  Hit a Massive Pothole - Need New Wheels jasonsargonautalis_imp 18 1,464 12-09-2021, 01:33 AM
Last Post: Raceman_imp
  Tyres again - spoked wheels - pressures Rogerdj_imp 3 352 07-06-2021, 08:24 PM
  Anybody paint their wheels black on a '13? boynton6spd_imp 2 329 06-14-2021, 11:08 PM
Last Post: MrBob_imp
