Cable squeak
Hello, I just picked up a 2014 CB1100 in black and love it! I have a question about the cable though...the throttle cables to be exact. At slow speeds and when stopped, turning the handle bars makes a squeak. Its the throttle cables rubbing stuff. They dont look improperly routed, but is there any quick tips for eliminating that squeak? Kinda makes it sound like a piece of junk lol
(06-19-2014, 10:21 AM)Dan17059_imp Wrote: Hello, I just picked up a 2014 CB1100 in black and love it! I have a question about the cable though...the throttle cables to be exact. At slow speeds and when stopped, turning the handle bars makes a squeak. Its the throttle cables rubbing stuff. They dont look improperly routed, but is there any quick tips for eliminating that squeak? Kinda makes it sound like a piece of junk lol
Sounds like the dealers problem not yours. If you bought it privately then find out where the noise is made and either lubricate or increase the clearance as appropriate. It's difficult to diagnose by internet!
PS. Standby for a post from the forum moderator. Over to you ferret Smile.
What do I know about cables squeakin?. I'm headed to the garage now to see if mine squeak.
Edit: Nope!
(06-19-2014, 10:57 AM)The ferret_imp Wrote: What do I know about cables squeakin?. I'm headed to the garage now to see if mine squeak.
Edit: Nope!
ferret , look a little closer. And I thought you were observant Smile.
Well im not running it back to the dealer just for squeaking cables. I'll let it go for a few hundred miles and see if it quits or maybe spray some silicone on them. I cant imagine mine is the only one to ever squeak like this..
(06-19-2014, 12:37 PM)Dan17059_imp Wrote: Well im not running it back to the dealer just for squeaking cables. I'll let it go for a few hundred miles and see if it quits or maybe spray some silicone on them. I cant imagine mine is the only one to ever squeak like this..
Something squeaking, something not right.
Well, i was just able to take a closer look. I did not see any other way the cables could be routed as they are held in by 2 wire hooks. I DID however see where the one cable develops a slight kink when turned fully right. After seeing this, I probably will take it back and have them look it over and maybe even compare it to the 2013 model they still have..
having throttle cables squeak or kinking is a safety issue and get you in a bad situation to you and maybe some one else, you need to fix the promblem NOW.
Wayne is right you know.
Edit: Nope!
C'mon ferret, look again. You can do better than that Smile
I must be denser than morning fog on the BRP .. I'm as sharp as a tack pounded into concrete.. I'm seeing as well as a blind owl at noon....I obviously don't see what you must be seeing. Dodgy
  "Seat Lock" cable unseated. 17-CB-002 10 941 08-27-2025, 08:19 AM
  Throttle cable exposed misterprofessionality 7 1,178 06-12-2024, 11:53 AM
  GPS power cable The Gecko_imp 10 958 10-06-2023, 12:40 AM
Last Post: suhawk305
  Throttle cable replacement Stoked907_imp 1 265 05-20-2022, 09:35 AM
  Cable Lubrication ? bflint 23 1,873 07-26-2021, 08:09 AM
Last Post: max
  Throttle Cable Replacement olekzap_imp 13 1,146 06-21-2021, 09:45 PM
  Throttle Cable oldgoat01_imp 7 1,024 01-15-2021, 06:33 PM
  Cable tie - reusable? TXBikerGuy 14 984 05-27-2020, 12:23 AM
Last Post: jtopiso_imp
  throttle cable replace x6m_imp 23 1,214 02-26-2018, 06:18 AM
Last Post: Olyrider
  2017 CB1100 RS - Heated grips cable sleeve hdvalente_imp 2 238 05-21-2017, 07:17 AM
Last Post: hdvalente_imp
