"Seat Lock" cable unseated.
While re-installing the battery back under the seat I noticed that the "seat lock" cable was halfway out of its original position and when I push it down, it clicked and lock itself into the correct position.
After a close up inspection, I understood that the cable came out of its seating clamp due to too much empty space above it. (hole/empty space is for inserting the cable).
When I moved the "seat lock" cable up/down, it came out of its normal position - should this happen when the seat is latch down and locked, It will be extremely difficult removing the seat.
To prevent future issue with the cable coming out of its original position, I inserted a short piece of rubber hose on top of the "seat lock" cable, push it all the way in and tape both items together.
By performing the modification, the "seat lock" cable will not come out of its position again.
See the picture attached.
Before modification
After modification
I looked at mine and can certainly see how that could be a problem! There have, in the earlier forum, been several cases like that.
I took a small zip tie and secured the cable to the bottom of the bracket so it can't be pulled up, which will do the same.
I did mine with a zip tie, fixed forever
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Good advice guys, thanks. Mine looks ok. It looks like Honda could have done a better job when designing this. If it does pop out of position when the seat is installed, how do you get your seat off?
Checked mine, too and it was tightly inserted, but secured with zip tie all the same. Tube-n-tape, ties...both good ideas to avoid a difficulty on the road where you don't want nor need the aggravation.
I've checked mine and it looks and feels rock solid so I'm going to zip tie it immediately! Big Grin
What Cormanus said Smile
But I did more of what 17cb did. A piece of rubber hose and then a tie wrap.
Dave, there was a thread or 2 on the old board, maybe ported over to here, that went in to it.
From what I remember, it was a J. O. B. Can’t remember any details though.
Holder of the CB1100forum Secret Decoder Ring
2012 ST1300
2013 CB1100
I find your lack of RLETs disturbing
(08-26-2025, 02:08 PM)Lord Popgun Wrote: What Cormanus said Smile
Thank you Lord, I'll see if I can find it.
Sorry, but is J.O.B. an acronym for something?
(08-26-2025, 10:16 PM)dave Wrote: ... is J.O.B. an acronym for something?
I wondered the same thing, but hadn't got around to looking it up. There's some suggestions here.
I thought it was just a way to say something was a JOB. Thats how I’ve always heard it used and used it.
2012 ST1300
2013 CB1100
  18" Tubed Tyres UK Davidjill_imp 2 383 07-24-2024, 10:12 PM
  Front ABS Brake"Rain Stick" noise bflint 3 462 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Throttle cable exposed misterprofessionality 7 1,209 06-12-2024, 11:53 AM
  Delkevic 9" Oval Install Problems. jbird06_imp 4 468 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  GPS power cable The Gecko_imp 10 1,013 10-06-2023, 12:40 AM
Last Post: suhawk305
  Seat lock is stuck iansulkowski_imp 4 475 09-11-2022, 09:43 PM
Last Post: World8_imp
  Throttle cable replacement Stoked907_imp 1 276 05-20-2022, 09:35 AM
  2017 EX "Rim width Sizes" 17-CB-002 2 336 04-05-2022, 03:21 AM
Last Post: 17-CB-002
  Cable Lubrication ? bflint 23 1,982 07-26-2021, 08:09 AM
Last Post: max
  Do your gears "clunk" while downshifting? rjk555_imp 65 4,839 07-10-2021, 02:08 AM
