2017 CB1100 RS - Heated grips cable sleeve
So, I was looking at some pictures of the 2017 RS model (maybe comes with heated grips as stock item?) and noticed two things:
1- There is a bracket + cable sleeve for the right heated grip, but I couldn't find these parts on the parts diagram for the RS (it shows standard grips only) - Parts Lists thread by Cormanus (great by the way, thanks!);
2- The control cables are now secured with a clamp that is not attached to the handlebar (CLAMP, HARNESS 90690-MEF-800);
I am going to order the clamps (both sides) and I was wondering if there is another parts link that I could try to find the other parts for the heated grips. Any help?
Thanks!!
I found this link:
https://www.bike-parts-honda.ca/honda-mo...04/2/25247
It shows the bracket in the drawing but not under the parts list.
I will send an email to Mr. T and see what he finds.
Mr. T was able to find the part number and ship it to me:
And ordered a couple of different plastic clamps because I was not sure which one was it:
The clamp that matches the picture is 90690-MEF-800.
The heated grip bracket attaches to the lower bolt that holds the brake cylinder:
Used rubber rings to hold the wire to the bracket:
  "Seat Lock" cable unseated. 17-CB-002 10 1,009 08-27-2025, 08:19 AM
  Workshop Manual and Parts Book 2017 on CB1100's sprint 5 602 01-13-2025, 06:10 AM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 290 08-01-2024, 02:33 AM
  Throttle cable exposed misterprofessionality 7 1,212 06-12-2024, 11:53 AM
  GPS power cable The Gecko_imp 10 1,015 10-06-2023, 12:40 AM
Last Post: suhawk305
  Throttle cable replacement Stoked907_imp 1 276 05-20-2022, 09:35 AM
  Cable Lubrication ? bflint 23 1,993 07-26-2021, 08:09 AM
Last Post: max
  Throttle Cable Replacement olekzap_imp 13 1,197 06-21-2021, 09:45 PM
   Heated Grips on the EX michael1954 25 1,928 01-21-2021, 04:24 PM
Last Post: michael1954
  Throttle Cable oldgoat01_imp 7 1,045 01-15-2021, 06:33 PM
