Throttle cable replacement
Hello friends. I am replacing throttle cables on my 2014. I have gotten as far as removing the tank and some of the vacuum lines that are in the way. Any tips or tricks to getting the cable locked into the throttle flapper? Should I remove my airbox or disassemble in other ways. Thank you in advance. Cheers
check here
http://cb1100forum.com/forum/showthread....tle+cables
  CB1300 headlight bucket replacement spechg 5 369 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 962 01-19-2026, 05:09 AM
  Josh’s bigger throttle bodies project PowerDubs_imp 50 4,193 10-14-2025, 05:04 PM
Last Post: jikemenkins
  "Seat Lock" cable unseated. 17-CB-002 10 976 08-27-2025, 08:19 AM
  Rear brake pad replacement LongRanger_imp 39 3,468 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 518 02-13-2025, 06:25 AM
  Throttle cable exposed misterprofessionality 7 1,190 06-12-2024, 11:53 AM
  throttle operation The Gecko_imp 6 580 03-07-2024, 09:39 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 475 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  GPS power cable The Gecko_imp 10 985 10-06-2023, 12:40 AM
Last Post: suhawk305
