Throttle cable exposed
I noticed this morning on the way to work that the protective sheath around the throttle cable has split, exposing the metal throttle cable underneath. It looks relatively recent, because the cable itself is still silver and shiny. my initial instinct is to put the sheath back together and get it wrapped up tight with electrical tape, but if anybody else knows any good tricks to sealing this up that would help. Or should I just have the cable replaced?
This happened to me also I had a rub spot underneath the fairing. I just electrical taped over it to keep debri from getting in there and made sure I lubed the cable after.
Been like that for a few years now I think, never had a problem.
Just "cover" it. You dont have to go real tight with the tape wrapping wise. No need to pull it tight to finish it off like a wire. You dont wanna restrict movement of the wire from being overly tight.
Black duct tape might even be a better option since it will just stick around the sheathing instead of having to go a little tighter with electrical tape to make sure it sticks.
i don't know how to lube a cable properly but it couldn't hurt to spritz a little lithium grease in where the cable is exposed and work it around before sealing the whole thing up. I'll take the black duct tape advice. that does seem like it would hold the two halves of split sheath together better.
Pretty straight forward and important maintenance if you want to watch a few videos on it.
I believe that guy MC garage thats an off shoot of revzilla channel but for like the DIY mechanic has a good video on it.
You open the throttle side controls and basically just squirt CABLE lube down the send and return lines (idr if the CB has a return line or not like my yamahas).
Motion pro makes a tool that makes it alot easier/less messy. You put your cable end inside the clamp/vice tool and it has a port to squirt the lube into.
All that aside the duct tape should work good. I would just consider lubing the throttle cables if you have never before.
https://youtu.be/aQnMdOL09uY?si=JFddToxrevE0SJnH
https://youtu.be/fI6GX2oJkao?si=Flr11VhygCQ87G1N
The CB110 has both send and return cables. Don't ask how I know.
(06-10-2024, 11:58 PM)Cormanus_imp Wrote: The CB110 has both send and return cables. Don't ask how I know.
[Image: 5b4bb9b892f6bae886f15a71e52e94e0.png]
(06-11-2024, 03:43 AM)m in sc_imp Wrote: id use heat shrink, but tapes is ok.
cable oiling tool. https://www.amazon.com/Tools-Motorcycle-...d_source=1
use cable lube, not lithium. lithium holds moisture in my experience. ( i know its not supposed to).
[url=https://www.amazon.com/Chain-Cable-Penetrating-Fluid-Lubriplate/dp/B08RY2T33X/ref=sr_1_9?crid=1NJV518V7VE63&dib=eyJ2IjoiMSJ9.p5gsfdbhaO_GAqGXC3DV9tTnk9Wt7VB0xyDHAlkeR5fnL2oHmvI6opy7NSg​nl6fcd85B81xncZG511fluIet01j2gZC_CXdV-o3zhNBVeK8EaO3vB8X-pWzjNzKIacplLq-BVngA_BQRDGRzqzXZmXr1BPLk-h7fRzr5mugqtyM8q_s18XAnL6PLRI0cu-0p3oA9m4A9O2aAEJLYgf51r9ee4NpZYwzjiiw2-9xbDVurZRkZqzR9fO1Kj9CqjTQk8_Pd44dHbAG1HZ1LvgaAAV1iANxPlV0KtG9Zh9zEqy0.LX0K3Ym0Y​ikpYv1sG-4tBm58D1wa2FlIWMSS6LEUdGw&dib_tag=se&keywords=cable+lube&qid=1718127744&s=industrial&sprefix=cable+lube%2Cindustrial%2C79&sr=1-9]https://www.amazon.com/Chain-Cable-Penet...C79&sr=1-9
Heat shrink is a good idea if the cable is already out of the housing I didnt think it that
Depending on the split- liquid electrical tape is handy to have in the garage as well.
  Josh’s bigger throttle bodies project PowerDubs_imp 50 4,197 10-14-2025, 05:04 PM
Last Post: jikemenkins
  "Seat Lock" cable unseated. 17-CB-002 10 976 08-27-2025, 08:19 AM
  throttle operation The Gecko_imp 6 582 03-07-2024, 09:39 AM
  GPS power cable The Gecko_imp 10 987 10-06-2023, 12:40 AM
Last Post: suhawk305
  Throttle cable replacement Stoked907_imp 1 268 05-20-2022, 09:35 AM
  Cable Lubrication ? bflint 23 1,918 07-26-2021, 08:09 AM
Last Post: max
  Throttle body sync? Whoops 6 532 07-10-2021, 02:22 AM
  Throttle Cable Replacement olekzap_imp 13 1,163 06-21-2021, 09:45 PM
  jerky throttle response... explained (video) jtopiso_imp 0 203 06-09-2021, 04:28 PM
Last Post: jtopiso_imp
  Odd Throttle Clicking When Accelerating or Decelerating codyp1814_imp 7 701 01-29-2021, 01:04 AM
Last Post: supruet_imp
