Torque-Stripes?
I have a question for you all. I've noticed on motorcycles sometimes the bolts have white paint marks on them, "torque-stripes," to indicate the bolts have been torqued. My question is: are these done at the factory, or do mechanics also apply the marks post-factory after they have torqued the bolts? Here is why I ask - I bought my CB1100 used with 526 miles. I asked the dealer if it had had the first service done. He said - "I'm sure we did it when it was brought in at 526 miles." I pressed him, and he maintained it had been done. However, when I look at the oil filter, it has the torque-stripe marks on it. If they were applied at the factory, it would imply the filter has not been replaced, and the first service has not been done. Anyone know?
Never heard of dealers doing them. Anyone else?
The "torque-stripes" are applied at the factory and I have never seen a mechanic do it at our shop or anywhere else. I have removed and replaced many bolts without removing the white mark. I honestly don't recall seeing that on an oil filter, I know it wasn't on my CB. Nobody, but nobody, torques an oil filter on. Maybe it was intended to just be a check that it is tight?
You know for $35 and 30 minutes work you can do it yourself and you will KNOW it was changed.
Any shop worth a hoot will have a paper trail on any work done in the shop. Parts have to get deleted from inventory, mechanics have to get credited (even on used stuff there is an internal labor rate work gets charged to)
I'd ask them to see the work order and if they can't provide one I'd go someplace else and buy oil and an oil filter and change it myself. It's really easy on this bike.
http://www.cb1100forum.com/forum/showthread.php?tid=202
Thanks so much for the replies. Yeah, I'll go to the dealer and ask to see paperwork. If not, I'll follow your tutorial. I asked another mechanic and he said the dealership I bought the bike from has been around forever and is very respectable and they probably did the service, but I'll ask for paperwork anyway. If not, I'll follow the tutorial that The Ferret provided.
Thanks!
(02-14-2015, 05:16 AM)KennyB_imp Wrote: The "torque-stripes" are applied at the factory and I have never seen a mechanic do it at our shop or anywhere else. I have removed and replaced many bolts without removing the white mark. I honestly don't recall seeing that on an oil filter, I know it wasn't on my CB. Nobody, but nobody, torques an oil filter on. Maybe it was intended to just be a check that it is tight?
Yeah, maybe it was just a check to show it was tightened. Or maybe it's just a white smudge that I'm thinking is a torque-stripe. Either way, thanks for input!
Just change it, no big whoop. Smile
I agree that changing the oil yourself is simple and inexpensive. The problem I would have is if the dealer lied about doing it. I'd like to be able to trust the dealer that sold me the bike...
(02-14-2015, 05:29 AM)The ferret_imp Wrote: You know for $35 and 30 minutes work you can do it yourself and you will KNOW it was changed.
$35? I did mine yesterday. 4ltrs of Mxxxx xxxx xW-xW oil, KN 204 filter and crush washer came to AUD105. That's about USD 80 at current exchange rates. That's not at a dealer but at a motorcycle accessories shop, marginally cheaper than the dealer.
Just as a matter of interest, after draining the oil and replacing the filter (not torqued), washer and plug bolt, I took 100ml from the oil container, poured the remainder into the bike, and the oil quantity check (as per the manual) came to exactly the upper fill line. Easy peasy.
Doing the remainder of the service and checking the bike over, I was disappointed to find that the left front indicator retaining bolt had come off a turn or two leaving the indicator "wobbly". And this is after only 48,000kms! Obviously not torqued correctly on assembly. Just not good enough! I'm considering lodging a formal complaint to Honda.
Cheers.
Gallon of Honda GN4 10w30 $23 Honda filter 15410-mfj-do1 $12 total $35 at my local dealer
( actually I just looked and online I can find the oil for $19 and the filters for $9)
Cheers.
You've had real trouble with that bike Pterodactytl—blown tail light globe at 40,000 kms and a loose nut at 48,000 kms. You should send it back and demand a replacement!
  Torque value question Jonnyteabag_imp 9 643 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 642 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 395 04-03-2021, 01:35 AM
  Engine mount bolt torque value TCinNC_imp 43 2,546 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 682 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,095 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,194 10-25-2018, 02:25 AM
Last Post: HBFL_imp
  Torque spec for motor mount? PAULIBIKER_imp 3 379 09-10-2018, 07:35 AM
  Torque wrench woes postoak_imp 17 1,026 08-10-2018, 08:44 PM
  Oil filter torque values Houtman_imp 23 1,458 04-05-2018, 08:49 AM
