Front Axle Pinch Bolt Torque ?
Just installed the Superbrace & want to retorque the axle pinch bolts. I guessed at 25 #, but would like something more accurate than my guess. Thanks, Rocket
When I installed my Superbrace, I referenced the ferret's thread on how to install fork gaiters for the pinch bolt torque measurements (19 ft lbs). I finally broke down and ordered the service manual yesterday but knowing how detailed the ferret is in his calculations, I have no doubt that it's spot on.
His thread is here: http://cb1100forum.com/forum/showthread.php?tid=3289 In post #3, he lists the torque values at the end.
Honda service manual says 17flbs for the upper triple clamp bolts and 32flbs for the lower.
19flbs for the pinch bolts.
(03-16-2015, 06:48 AM)redbirds_imp Wrote: Honda service manual says 17flbs for the upper triple clamp bolts and 32flbs for the lower.
I will NEVER trust the ferret AGAIN.
Am I correct in assuming the "clamp bolts" are the same as the "pinch bolts"?
You were right the first time. I screwed up and listed the triple clamp values then corrected my mistake and listed the values for the pinch bolts.
Like I said, I never, ever, doubt the ferret.
ROFL
ROFL Dang you guys had me confused for a minute.
I'm still not sure if I posted it right or wrong. guess it depends on what you are labeling pinch bolts. I would think those would be the two little ones down by the axle on the front of the lower legs.
Thanks for the help.
Ferret: Yes the AXLE pinch bolts.
  Rear axle diameter 2014 vs 2017 ashishNJ_imp 4 545 08-28-2023, 06:07 PM
Last Post: dopaytoplay_imp
  Front sprocket bolt cant be moved misterprofessionality 55 4,634 03-13-2023, 12:18 PM
  Torque value question Jonnyteabag_imp 9 670 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 654 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  rear axle nut question binarkansas_imp 12 988 05-21-2021, 01:49 AM
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 432 04-03-2021, 01:35 AM
  Rear Axle Nut Billie_imp 7 583 03-22-2021, 12:56 PM
Last Post: Billie_imp
  Fork Tube hex head bolt tool fitment ? bflint 8 743 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Engine mount bolt torque value TCinNC_imp 43 2,751 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 734 04-11-2019, 07:04 AM
