Rear Axle Nut
Just replaced the tires on my 2014 CB, when I took the rear wheel off I noticed there was no C shaped clip on the end of the axle.
My Harleys all have had a clip to prevent the axle nut from ever backing off, now I know HD's vibrate more than this CB but am I missing something here?
So I put some blue locktite on the threads and tightened the nut down, anything else?
I don't ever recall removing a C clip off a Japanese bike in my travels. I have taken cotter pins out of Italian axle nuts.
The service manual does not call for thread locker on the axle nut. Torqued to spec it will not come loose.
Yeh I saw that about the locktite, but thought better safe than sorry, Thanks guys.
The rear axle has a stainless steel spring washer built into it that is always tensioning the nut against the thread. Look up Fuji Lock Nut. Unlike nylon-lined lock nuts, these do not fatigue and are reusable indefinitely. Nylocks are not reusable unless the plastic inside is heated and melted.
(03-20-2021, 03:24 PM)pekingduck_imp Wrote: The rear axle has a stainless steel spring washer built into it that is always tensioning the nut against the thread. Look up Fuji Lock Nut. Unlike nylon-lined lock nuts, these do not fatigue and are reusable indefinitely. Nylocks are not reusable unless the plastic inside is heated and melted.
Thanks
Correction -
The rear axle NUT has a stainless steel spring washer built into it that is always tensioning the nut against the thread.
(03-21-2021, 12:37 PM)pekingduck_imp Wrote: Correction -
I figured thats what you meant, thanks for the info.
  Rear axle diameter 2014 vs 2017 ashishNJ_imp 4 546 08-28-2023, 06:07 PM
Last Post: dopaytoplay_imp
  rear axle nut question binarkansas_imp 12 994 05-21-2021, 01:49 AM
  New Rear Tire and Rear Brake Pads memphismike_imp 5 568 06-11-2018, 09:35 PM
  front wheel axle spacer collars switched Searcher_imp 6 511 05-25-2017, 10:36 AM
Last Post: Searcher_imp
  Rear Axle Torque? JustPassinThru_imp 3 330 06-16-2015, 01:54 PM
Last Post: JustPassinThru_imp
  Front Axle Pinch Bolt Torque ? rocket_imp 8 712 03-16-2015, 11:32 PM
Last Post: rocket_imp
  83lbf-ft on the rear axle nut Razorbacjac_imp 21 1,213 03-15-2015, 12:19 PM
   Axle diameters?? For new tool rboe 2 336 09-07-2014, 11:56 PM
Last Post: rboe
  Rear Axle nut... HikerToo_imp 6 505 07-02-2013, 11:33 PM
