Weight and preload
Does anyone know what settings on front and rear suspensions for different weights?
Factory rear is number 2
What weight is that intended for?
If you ride a long distance 2-up should you change to stiffest setting?
There was a unofficial survey on this topic in a thread not too long ago. It seemed like most folks between 185-210 lbs. we're running with two lines showing on the forks (so 1 line stiffer than the stock setting), and with rear shock preload with at least some preload (nobody ran on the softest setting). I'm about 205 lbs. and prefer only 1 line showing on the forks -- it helps avoid that rough, slapped down feeling my bike would get from bottoming if I hit too large of a pavement imperfection. I've likewise stiffened the rear for pretty much the same reason. I did a 500 mile ride last weekend and experimented, and the CB feels much more dialed in now for real, rutted / potholed road riding. You didn't ask, but I should add that some people get a better ride using a fork brace. Always an option. But I'm pretty happy just using the stock fork adjustments so far.
For two-up, 2-adults riding, I'd probably stiffen the rear shock (and maybe the fork, it's easy). Depends on how big the passenger is. 130 pounds or more, and I'd add full preload. That's a fair amount of mass, right atop the rear suspension.
  Weight limit on genuine Honda rear rack DaveP_imp 14 1,224 11-17-2022, 02:57 AM
  Easy bar end weight removal brian10x_imp 6 619 06-06-2022, 01:04 AM
Last Post: 1973cb750
   CB's max weight j3gq_imp 36 2,562 11-26-2020, 11:32 AM
  Wheel weight Brad14_imp 7 585 07-25-2020, 01:56 AM
Last Post: Brad14_imp
  Too much weight to balance front tire? thebrawnyman_imp 11 979 09-11-2019, 09:37 PM
  Weight of the OEM Wheels on the 2013/2014 std models? misterprofessionality 7 547 04-04-2019, 09:24 PM
  Stock header weight PowerDubs_imp 6 528 08-25-2018, 09:56 AM
  Bar End & Internal Weight Removal 2017EX_imp 1 231 08-05-2017, 07:07 AM
Last Post: use2b_imp
  Adjusted my preload today HondaJon_imp 12 893 12-31-2016, 02:37 AM
Last Post: tomas_imp
  weight wingman1946_imp 13 1,017 08-18-2013, 11:29 PM
