Too much weight to balance front tire?
Hello All,
Recently bought a set of Pirelli Sport Demons to replace the factory tires on my 2014 CB1100. After mounting the tires, I brought them to a local motorsports dealership to have them balanced. After retrieving them I was told the rear tire balanced fine but the front tire took 3 oz. to balance out. He then told me that this is almost three times the required weight to balance an aluminum, front motorcycle wheel. They then rotated the tire 180 deg. and it still took 3 oz. to balance. I bought the tires through Bike Bandit and reached out to them and Pirelli. Bike Bandit told me to contact Pirelli and Pirelli told me to contact Bike Bandit. Took the bike out, since it needed to be moved to another location, and no issues or vibration ever came from the front tire even up to ~80 mph. Should I stick with this tire or attempt returning it?
Thank you,
If it's working fine, I'd stick with it.
(09-10-2019, 02:55 AM)LongRanger_imp Wrote: If it's working fine, I'd stick with it.
Thanks for the insight, I appreciate it.
(09-10-2019, 03:55 AM)m in sc_imp Wrote: same here. ive seen that before, and it was fine but its rare. luckily my local shop matches online prices so if one was that far out, he'd return it to vendor and put a better one on. Hes done that for me 3x over the years w/out having me to ask. other times i was like screw it and ran with it . never an issue.
Thank you!
I've used up 100+ tires on the race track and wouldn't sweat it if balanced. I've stuck on up to 2.5 oz and spun it up to 140+ on track. (GSXR 1000)
I'd say you're fine.
My Bonneville currently has two strips of weights on the back wheel. The shop who has changed my tires for years commented that it's more weight than they're used to, but it would be ok unless I felt any vibration. Granted, that's a Malaysian-built spoke wheel, not a Honda-built cast wheel, but I've had smooth riding on it for a few years now. If it rolls smoothly, probably not a big deal as long as it's confirmed that there's no damage to the wheel.
(09-10-2019, 02:07 AM)thebrawnyman_imp Wrote: Hello All,
Thank you,
3 oz (85 grams) is indeed a fair amount to be out, but it happens. I would hope the shop marked the tire for the initial heavy spot to verify the re-balance heavy spot was in the same part on the tire.
The tire should have a yellow circle or dot on the sidewall to mark the light spot on the tire that is aligned with the valve stem location. This would maybe require a little less weight. But if there is no affect in riding, I wouldn't be concerned.
i had an Avon rear tire take 3 oz's once, but that seems like a lot for a front tire. that said, sport demons are my favorite tires on this bike so far.
(09-10-2019, 09:41 AM)jimgl3_imp Wrote: i had an Avon rear tire take 3 oz's once, but that seems like a lot for a front tire. that said, sport demons are my favorite tires on this bike so far.
How many miles do you have on them? These are my first set after the factory ones.
Ride it!. I’m on my 3rd and last set of Sport Demons on a Guzzi V7R. A 750cc (395 pound bike when dry) at a little over 7,000 miles. Good grip. No complaints about handling. However, ABYSMAL tire life. What it’s cost me now in having tires put on I could have paid for another set of tires with much better longevity. Please stick around the forum and let us know how they wear. I’d be interested to see if I’m an outlier in that area but don’t think so. Have heard this from others that use them. Make SURE you keep the front inflated to spec to prevent premature cupping from starting.
Frulk, I had a similar disappointing experience with Sport Demons on my V7C. They were fine while they lasted, but we're talking maybe 4000 miles max.
  Injectors syncro/balance TheLegend 15 2,082 11-10-2025, 02:07 AM
Last Post: TheLegend
  Rear only tire on the front? mattmcuomo@yahoo.com 5 581 10-09-2023, 06:05 AM
  Weight limit on genuine Honda rear rack DaveP_imp 14 1,204 11-17-2022, 02:57 AM
  Easy bar end weight removal brian10x_imp 6 617 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Healtech eSync tool- synchronize balance throttle bodies PowerDubs_imp 11 1,041 12-06-2020, 06:43 PM
Last Post: jtopiso_imp
   CB's max weight j3gq_imp 36 2,486 11-26-2020, 11:32 AM
  Wheel weight Brad14_imp 7 571 07-25-2020, 01:56 AM
Last Post: Brad14_imp
  Weight of the OEM Wheels on the 2013/2014 std models? misterprofessionality 7 536 04-04-2019, 09:24 PM
  Stock header weight PowerDubs_imp 6 506 08-25-2018, 09:56 AM
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 942 07-18-2018, 06:50 AM
Last Post: SportsterDoc
