Rear Axle Torque?
This has probably been noted before; but my search isn't finding it.
It's time to snug up the chain a little bit. It's all pretty straightforward - EXCEPT torquing the axle bolts down.
Since I have a poor feel, I use a torque wrench on EVERYTHING.
Thanks to one and all for input.
83 foot pounds iirc.
I cant remember if you have a 13 or 14
13s are 83 ft lbs, 14 s are 65ft lbs ( at least the dlx, not sure anout 14 std)
(06-16-2015, 01:46 PM)The ferret_imp Wrote: I cant remember if you have a 13 or 14
It's a 2014.
65 ft-lbs. Good.
Now, all I have to do is remember to loosen them before trying to adjust the chain with the positioners - or I'll strip them out like Pirsig did.
  Rear axle diameter 2014 vs 2017 ashishNJ_imp 4 546 08-28-2023, 06:07 PM
Last Post: dopaytoplay_imp
  Torque value question Jonnyteabag_imp 9 674 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 655 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  rear axle nut question binarkansas_imp 12 993 05-21-2021, 01:49 AM
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 432 04-03-2021, 01:35 AM
  Rear Axle Nut Billie_imp 7 584 03-22-2021, 12:56 PM
Last Post: Billie_imp
  Engine mount bolt torque value TCinNC_imp 43 2,788 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 742 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,145 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,249 10-25-2018, 02:25 AM
Last Post: HBFL_imp
