Shifter Lever Height Adjustment
I/ve looked thru the shop manual but cannot find any reference to raising or lowering the shifter lever. Is it possible to raise the lever? I installed a different peg and feel I could shift better if the lever was higher. I noticed there is a connecting rod which is threaded on both ends but cannot readily see where the lower end attaches. If that is the adjustment for lever height, does the rod need to be lengthened or shortened by adjusting the nuts on the rod itself? Also, if adjustable, how much can it be adjusted?
Yes loosen the locknuts, and twist the rod (not sure which direction but adj is very noticeable as you are doing it. I measured from center of lever tip to ground and I think I adjusted mine about 1/2" but not sure how much total adj there is.)
(08-01-2015, 07:21 AM)The ferret_imp Wrote: Yes loosen the locknuts, and twist the rod (not sure which direction but adj is very noticeable as you are doing it. I measured from center of lever tip to ground and I think I adjusted mine about 1/2" but not sure how much total adj there is.)
Thanks for the quick reply. I'm off to the garage to tackle this.
Cool. Let us know how it works out for you
Here is an interesting thread on shift lever adjustment
http://cb1100forum.com/forum/showthread....hift+lever
(08-01-2015, 08:30 AM)The ferret_imp Wrote: Cool. Let us know how it works out for you
My first adjustment was too high. My big foot couldn't handle it so I lowered it. I've tweaked it a couple times, since it is so easy an adjustment to make with one wrench. Since I had the pivot bolt off in order to remove the pin which holds the foot peg, I installed a Goldwing peg but had to slightly modify it to fit under the pivot bolt. I also greased the pivot bolt while I had it off to allow for smoother shifting. My shifting has always "popped" right into the proper gear and I did not want to lose that function. One of these days, I'm gonna try some high speed shifting to see if the cycle will do it. Wink
  Valve Adjustment Shims dave 13 664 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Big Feet, Big Shoes, Small shifter MagnaRider 8 475 04-17-2026, 12:13 AM
Last Post: LucienLeFranc
  Valve Adjustment and Camshaft Removal dave 5 612 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 852 08-29-2025, 10:46 AM
  Valve Adjustment Intervals CBRider_imp 32 2,800 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Replace clutch Lever Davidjill_imp 10 949 02-06-2025, 01:27 AM
  Rear Brake Pedal Adjustment Gone in 60 12 1,111 04-04-2024, 08:18 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,477 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Front brake lever ROCK hard ichiban_imp 37 3,779 02-10-2023, 10:54 PM
  Long shift lever Sam Mac_imp 1 261 02-08-2023, 08:30 AM
