Valve Adjustment
Does Honda recommend that any of the bolts that attach the camshaft holders be replaced when the cams are removed? How about the cam shaft drive sprocket attachment bolts?
Thanks.
No to both questions. The service manual just says to torque them. They are not shown as special bolts in the torque spec section or mentioned as special in section 7 (cylinder heads/valves) in removal and re-installation.
For the cam flange holder bolts it says to put engine oil on the threads and seating surface.
For the sprocket bolts it says apply a locking agent. Book says use medium strength unless otherwise specified. Nothing specified so use medium.
It also shows/says the flange holders must be loosened and tightened in a several steps in a crisscross pattern from outside to inside or they may break. And do not forcibly remove the dowel pins from the camshaft holders.
Holder of the CB1100forum Secret Decoder Ring
2012 ST1300
2013 CB1100
I find your lack of RLETs disturbing
(08-26-2025, 06:28 AM)Lord Popgun Wrote: No to both questions. The service manual just says to torque them. They are not shown as special bolts in the torque spec section or mentioned as special in section 7 (cylinder heads/valves) in removal and re-installation.
Thank you Lord Popgun!
if you need the torque values let me know
2012 ST1300
2013 CB1100
Wink
(08-26-2025, 02:03 PM)Lord Popgun Wrote: if you need the torque values let me know
Thank you Lord.
BTW, I have RLETS on my bike!  Big Grin
Good, very good. A Padawan you are not! Smile
2012 ST1300
2013 CB1100
Wink
(08-27-2025, 07:00 PM)Lord Popgun Wrote: Good, very good.  A Padawan you are not! Smile
I had to look that word, Padawan, up.  Tongue
  Valve Adjustment Shims dave 13 752 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 652 03-21-2026, 04:49 PM
  Valve Cover Baffle lining ? bflint 6 986 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 3,182 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Rear Brake Pedal Adjustment Gone in 60 12 1,195 04-04-2024, 08:18 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,627 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,500 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 14,256 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 7,045 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 683 07-08-2022, 03:41 AM
Last Post: 1973cb750
