Big Feet, Big Shoes, Small shifter
So, I have above average size feet, and if I wear my steel toe boots which are required at my job, I can't comfortably get my foot under the shift lever to up-shift. I used to wear a barefoot hiking shoe that really gives me full movement of my foot, and I never had this issue.
Are there aftermarket longer shift levers that work with the CB and has anyone tried it?
Has anyone changed the location of the shifter relative to the spline shaft it sits on? I have it in the stock position and tonight I think I might try rotating it up a spline.
Edit: Going to try adjusting this after searching the forum some more.
Thanks
Also, the link between large feet and other certain male appendages being large is untrue. I just have large socks  Wink
'84 Honda Magna VF700 (Gone, but not forgotten)
'06 Yamaha VStar Classic 1100
'14 Honda CB1100 Std
Try moving it up a bit and see if your boot can fit under it. With the different BMWs I'm riding for work now, when I pick one up at the main location and bring it home to work on it and make deliveries, I'm finding that most shift levers are set a bit low, and brake pedals are a bit too high for my boots. I'm adjusting accordingly and it's much more comfortable and easier shifting.
I put a smaller rubber piece from the old Hondas on the gear shifter. It helps.
MAGNA means big, so cannot have small feet  Tongue
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
The problem may be that the shifter peg is too high or too low, in which case adjusting the height is done by loosening the nuts at both ends of the shifter adjuster rod will allow you to raise or lower the shifter tip.  The adjuster rod is like a turnbuckle, in that it has left hand threads and right hand threads.
The forward nut, which is visible, is left-hand thread.  The nut you can't see, at the back, is normal right-hand.  I bought a special wrench just to access it without removing the pivot bolt.
(04-16-2026, 11:47 AM)pekingduck Wrote: The problem may be that the shifter peg is too high or too low, in which case adjusting the height is done by loosening the nuts at both ends of the shifter adjuster rod will allow you to raise or lower the shifter tip.  The adjuster rod is like a turnbuckle, in that it has left hand threads and right hand threads.
I'm not sure I'll every need that specialty wrench, but I want one just because it looks cool.
(04-16-2026, 11:47 AM)pekingduck Wrote: I bought a special wrench just to access it without removing the pivot bolt.
If it isn't too much trouble, can you help point me to that wrench?  I would like to buy.
Motoloves of my life:
Heart
2014 CB1100 DX
2016 XR650L
I got it from Amazon, made by Sunex but no longer available.  Search for "10 mm Angle Wrench" and you'll find one made by Capri that looks the same.
Mac and Snap-on also have them for lots more.
Ordered. Thank you!
Heart
2014 CB1100 DX
2016 XR650L
  What's the function of these small holes beside injector zirconxi_imp 5 574 03-02-2024, 03:58 PM
  Big Feet Wagonpeddler_imp 12 1,117 05-01-2023, 02:42 AM
  Gear Shifter Crossfire_imp 3 802 02-19-2022, 12:09 PM
  Small quiz; brakes are dragging. max 31 2,394 11-29-2021, 12:20 PM
  Shifter Lever Height Adjustment White Dog_imp 4 424 08-03-2015, 11:48 PM
Last Post: White Dog_imp
