Front brake lever ROCK hard
Hey guys, I was bleeding the front brakes on my CB1100 18 YM. Everything is routine, cracked the 8mm bolt and start bleeding after a few pumps later there is no fluid coming out and the front lever is rock hard.
I have tried both front calipers and both have no fluid coming out! What the hell has happened any clues?
Never seen this on any bike I have owned.
(01-06-2023, 07:47 AM)ichiban_imp Wrote: Hey guys, I was bleeding the front brakes on my CB1100 18 YM. Everything is routine, cracked the 8mm bolt and start bleeding after a few pumps later there is no fluid coming out and the front lever is rock hard.
Yours is a 2017 ABS model I recall.
When you started bleeding one side, got a little fluid out before it went solid, and then closed the bleeder. At this point, was the lever still solid?
Then when you went to the other side, did the lever move? Did any fluid come out?
Did the lever go in at any point after the initial lever lockup on the first side?
Hi pekingduck, Yeah it's ABS but not the combined ABS like previous models. Yup a small amount of fluid came out(left caliper) then the lever was rock hard. Closed the bleeder lever was the same, went to the other side, and no fluid either.
Yes, the lever did not budge after the first lock-up. Looked in the service manual and it points to a potentially seized caliper. well it was fine before I bleed it
Maybe try a vacuum pump to extract instead of pumping the lever?
(01-06-2023, 09:17 AM)Gone in 60_imp Wrote: Maybe try a vacuum pump to extract instead of pumping the lever?
Thanks for the suggestion, I have left a few velcro strips on the lever hoping any airlock will clear overnight. I will have to buy a vacuum bleeder as last resort.
When I had BMWs, I remember a tech once telling me that a vacuum pump should be used rather than pumping the lever to change and bleed brake fluid for fear of upsetting the ABS system. But, that was BMW, which can be weird.
To see if you've got a frozen caliper, if you've got fluid in the sytem and plenty in the reservoir, and hopefully no air in the lines, I'd remove the caliper mounting screws and rock the calipers back and forth to let the rotors push the pads back into the calipers a bit. Then, reattach the calipers, squeeze the lever gently, and see if you can push the pads back against the rotors without any resistance. If you can't get the pads to move, then something in the system is upset, and your calipers are locking up for some reason.
Is the lever all the way in, or back out to normal. The lever/master cylinder piston may be seized, because, with the bleeder valve open, it was able to travel far further than in normal use.
I would cover the tank with plastic or lots of other protection, then try wrapping a rag around the master cylinder hose bolt. Slowly loosen the bolt and see if the lever will pump fluid out bolt area of the master cylinder. The master cylinder is suspect since it does the same on both sides.
Got a vacuum pump and that made no difference at all, after cracking the master cylinder banjo bolt and squeezing the lever nothing. This leads to the point, the brake master cylinder is goosed. I will have to get the dealers involved as I have a warranty on this bike. Shame just got the bike and this has happened.
such is life!
That is a shame. Hope the dealer is able to help. If it happened to my ‘13 with no warranty support, I’d order a master cylinder rebuild kit, tear it down, clean everything, make sure there was no wear or corrosion on the moving parts, replace the seals and put it back together.
(01-07-2023, 02:53 AM)Gone in 60_imp Wrote: That is a shame. Hope the dealer is able to help. If it happened to my ‘13 with no warranty support, I’d order a master cylinder rebuild kit, tear it down, clean everything, make sure there was no wear or corrosion on the moving parts, replace the seals and put it back together.
Yeah totally agree, I would have done the same if I did not have the warranty, the master cylinder repair kit is not that expensive either. This slight issue will not put me off the bike, Thanks for all your help really appreciate it.
  Replace clutch Lever Davidjill_imp 10 944 02-06-2025, 01:27 AM
  Front ABS Brake"Rain Stick" noise bflint 3 454 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Front brake inconsistent resistance ChiefJP_imp 16 1,356 06-14-2023, 07:46 AM
Last Post: bvictory_imp
  Sqealing front brake thop_imp 10 941 06-14-2023, 07:34 AM
  Long shift lever Sam Mac_imp 1 260 02-08-2023, 08:30 AM
  Clutch Lever Full Engagement odelegacy_imp 41 2,658 10-28-2022, 09:27 PM
  FRONT BRAKE TIGHTER omnimj_imp 2 259 09-08-2022, 02:43 AM
Last Post: 1985CB450_imp
  Brake lever gap from throttle. zirconxi_imp 16 1,223 10-25-2020, 06:26 PM
  Front brake.... pulsating??? mattmcuomo@yahoo.com 12 761 05-11-2020, 03:51 AM
Last Post: max
  Front Brake Drag 2017EX_imp 16 962 04-10-2020, 01:22 AM
