Throttle Position Sensor
Hi, does anyone know how to calibrate the throttle position sensor or the voltage range of TPS on your perfectly normal bikes?!!!
There is no mention of the normal voltage range of properly calibrated TPS on the service manual. There is some information (generic) on the internet about the voltage reading at Closed Throttle (CT) to be in the range of 0.45-0.55V and Wide Open Throttle (WOT) 4.5-5.0V.
Thanks heaps in advance.
(10-05-2015, 09:30 AM)BackOnTrack_imp Wrote: Hi, does anyone know how to calibrate the throttle position sensor or the voltage range of TPS on your perfectly normal bikes?!!!
According to the service manual ,on page 5-15, your ECM would store a DTC of 8-1, TP sensor low voltage(less than 0.3 volts} or DTC 8-2, TP sensor high voltage(above 4.93 volts) so I imagine that is the operating range from closed throttle to wide open throttle. You can measure these voltages with either a volt meter or a lab scope by back probing the correct leads at the sensor, KeyOnEngineOff, which is probably impossible to do on a motorcycle due to access to the plug. The only other way is with the Honda MCS scan tool as stated on page 5-13, which is more than likely displayed in the data stream. I would suggest not touching the adjustment unless one of the above codes are flashed as in the manual on page 5-15. This bike would flash the codes via the MIL blink pattern as described on page 5-13
Fiscy, Thanks heaps for the quick reply. Much appreciated.
Read this before you go digging into the bike...
http://cb1100forum.com/forum/showthread....ion+sensor
(10-05-2015, 11:47 PM)Randy B_imp Wrote: Read this before you go digging into the bike...
I tried this before my commute this morning and it really did make a difference. Small throttle openings and closings at low RPM are so much smoother now. Such an easy fix, too.
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,644 03-06-2026, 04:31 AM
  Oxygen lambda o2 sensor eliminator kit Davidjill_imp 4 563 11-09-2025, 06:23 AM
Last Post: AndyBeeMD
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 837 10-22-2025, 02:11 PM
  Josh’s bigger throttle bodies project PowerDubs_imp 50 4,122 10-14-2025, 05:04 PM
Last Post: jikemenkins
  How to remove O2 sensor CB1100AZ_imp 10 854 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Throttle cable exposed misterprofessionality 7 1,186 06-12-2024, 11:53 AM
  throttle operation The Gecko_imp 6 570 03-07-2024, 09:39 AM
  Bank angle sensor. Tezza_imp 8 745 08-06-2023, 05:57 PM
Last Post: Jurlie_imp
  fuel level sensor MBZM Rai_imp 11 891 04-11-2023, 11:38 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,322 06-03-2022, 01:16 PM
