throttle operation
Checked throttle operation (as I have done a few times before), anywhere between handle bar full left and (almost) full right the throttle free play is as prescribed in the books, but when I turn the handle bar that tiny little extra into full right all play is gone. Otherwise everything feels the way it should.
This situation is new, and I cannot see how this could be caused by the usual suspects. And simply using the adjuster seems counter intuitive, as it would change the setting over the full range. I can't see that the cable gets pinched somehow in the full right position.
Would you have any idea /s ?
I think I had this problem after swapping handlebars or taking the head light mount off when I did my fairing.
The cables route a certain way down along the side of the triple tree/behind the headlight bucket to the right and if its in front of or behind the guide bracket for the cables or the headlight bracket I believe you lose an inch or 2 or the cables "free play"
I may not have explained that well but in a rush. I can take pics later of how my house routed if needed. I think mine is outside of the "cable guide bracket" to give it some extra play after I went back to the stock bars but used risers.
Pics would be great, mvk.
Meanwhile i’ll check if the cable slipped in or out of a bracket ...
Really thanks a lot M,
quite possible I missed it in early controls.
Hey sorry it took so long, I forgot until I saw my notifications again just now.
My cables are back to being routed the way it came from the factory. [Image: ce862e0cbb1e9433200d5097e7ff3f1e.jpg]
Thanks mvk
(03-07-2024, 07:24 AM)The Gecko_imp Wrote: Thanks mvk
No worries, have you sorted it out?
  Josh’s bigger throttle bodies project PowerDubs_imp 50 4,205 10-14-2025, 05:04 PM
Last Post: jikemenkins
  Throttle cable exposed misterprofessionality 7 1,192 06-12-2024, 11:53 AM
  Throttle cable replacement Stoked907_imp 1 268 05-20-2022, 09:35 AM
  Synthetic oil & clutch operation Rogerdj_imp 8 669 11-08-2021, 06:41 PM
Last Post: Rogerdj_imp
  Throttle body sync? Whoops 6 533 07-10-2021, 02:22 AM
  Throttle Cable Replacement olekzap_imp 13 1,165 06-21-2021, 09:45 PM
  jerky throttle response... explained (video) jtopiso_imp 0 203 06-09-2021, 04:28 PM
Last Post: jtopiso_imp
  Odd Throttle Clicking When Accelerating or Decelerating codyp1814_imp 7 703 01-29-2021, 01:04 AM
Last Post: supruet_imp
  Throttle Cable oldgoat01_imp 7 1,041 01-15-2021, 06:33 PM
  Healtech eSync tool- synchronize balance throttle bodies PowerDubs_imp 11 1,036 12-06-2020, 06:43 PM
