 Oil Pressure Sending Unit Tap
Searched the forum but couldn't find the location of a oil pressure tap on my 2013 Honda CB1100.
Does anybody know where it isHuh There is a hex bolt on the opposite side of the take off for the oil cooler. Does any one know if this can be used and what size/thread it is?
Winter, time for a few modsTongue
ralph
If you want a pressure gauge I think your best bet would be to replace the sender for the idiot light with an actual functioning gauge. Or figuring out a way to get a dual headed sender that can run both.
http://www.hondapartshouse.com/oemparts/.../crankcase
It's part #7 in this diagram. Without looking at the bike, I think it's on the side of the engine case, in behind the rear brake lever.
(10-28-2015, 01:52 AM)kmoney_imp Wrote: If you want a pressure gauge I think your best bet would be to replace the sender for the idiot light with an actual functioning gauge. Or figuring out a way to get a dual headed sender that can run both.
Thanks, kmoneyThumbs Up That's just what I needed. I found these:
Wanted to mount it at the top between the tack and speedo. Guess I'm and old fart but I still don't like knowing what the oil pressure isThumbs Up Thanks for the help.
ralph
Ok, had time to find itBig Grin It's on the back side of the engine toward the rear just over the transmission in the rear oil gallery like so:
Thanks for the helpThumbs Up
ralph
ralph
ralph
OK, crud, that's not it. Disregard that photo.Undecided
I think the wire on the bottom leads to the oil sender.
(10-29-2015, 03:15 AM)Randy B_imp Wrote: I think the wire on the bottom leads to the oil sender.
Thanks Randy, I think that's what kmoney was saying alsoThumbs Up Boy that's gonna be hard to get to. I'm thinking I'm gonna drill out the oil gallery plug at the oil cooler and place an oil sending fitting there.
ralph
I was thinking there might be an aux oil pressure hole (like there is on my CB750), but it doesn't look like it. If you've got the service manual, there's a nice pic of the EOP switch on page 4-5. It's under a rubber cap.
(10-29-2015, 09:48 AM)Flynrider_imp Wrote: I was thinking there might be an aux oil pressure hole (like there is on my CB750), but it doesn't look like it. If you've got the service manual, there's a nice pic of the EOP switch on page 4-5. It's under a rubber cap.
Yah, there is an oil gallery plug in front by the oil cooler line behind the headers. I found a brass 5/6" X 1/8 npt fitting. I'm going to take the plug out and drill the center of it to 5/16" and tap the factory plug to install the sending unit.
I will have to paint it flat black to hide it and run the wiring through some vinyl conduit up to the headlight and tap into the running lights, but I think it's doable. There's enough room in the gage cluster to pop rivet a gage mounting to the back of the gage cluster. I had installed one on my CB750 back in the day between the two original gages and I miss itTongue
ralph
  low oil pressure light Garuda78_imp 16 1,074 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 864 10-09-2023, 07:51 AM
  low oil pressure light kaput norton1974_imp 11 981 03-28-2023, 08:58 AM
  Another source for plug-in LED flasher unit. FLYTYM_imp 7 628 01-31-2022, 09:53 AM
  Interesting article on tire pressure the Ferret 9 798 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  connection to control unit with OBD Enzofour_imp 54 3,562 03-15-2021, 06:42 PM
Last Post: Enzofour_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,275 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 888 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 635 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 421 10-23-2017, 04:51 AM
Last Post: kennyw
