connection to control unit with OBD
has anyone already tried to connect and what tools did they use?Confused
What exactly do you mean?
I have a GiPro gear shift indicator plugged into the DLC. AND I have the HealTech diagnostic tool that plugs into the DLC.
(11-17-2020, 12:40 AM)Lord Popgun_imp Wrote: What exactly do you mean?
sorry, as I have for the car, ODBCII connector connected to the ECU socket
Our bikes don't have an ODBCII connector. They use the Honda Diagnostic System.
Now, I know that bikes are going to get ODBC sometime, by government decree I think. If newer bikes have it I don't know about it. Sorry.
(11-17-2020, 02:47 AM)Lord Popgun_imp Wrote: Our bikes don't have an ODBCII connector. They use the Honda Diagnostic System.
is it possible to have it?:freddo:
I guess it is possible but I haven't heard anything about it. Maybe someone here knows more.. I don't know about the bikes you get in Italy. What year/model is it?
The recent Honda Africa Twin models support OBDII.
Only a few video's available on youtube using an adaptor lead from dlc to obd2 and a bluetooth dongle and android phone with the appropriate software;
https://www.youtube.com/watch?v=En8f92KBvEM
Presumably from indonesia but shows the relevant information, the system is using what is known as the "k wire" which is a bi-directional data protocol over one wire and ground at 12 volt logic data signal level instead of 5 volt logic.
(11-17-2020, 03:12 AM)Lord Popgun_imp Wrote: I guess it is possible but I haven't heard anything about it. Maybe someone here knows more.. I don't know about the bikes you get in Italy. What year/model is it?
cb 1100 ex 2014
[Image: d209c8e906e5d002f3379be164cba5cd.]
(11-17-2020, 04:39 AM)max_imp Wrote: Only a few video's available on youtube using an adaptor lead from dlc to obd2 and a bluetooth dongle and android phone with the appropriate software;
Who knows if this is compatible with our cb 1100?
https://www.hotnrare.com/it/healtech-dia...HT-OBD-H01
That is what I have. It works with a Windows computer. The only thing I have used mine for so far is data gathering for the idle problems some were having. It works with Hondas and even some outboards. I have a Honda outboard so that’s a plus! Haven’t tried it on the outboard though.
They also keep the software updated and you can update it when connected to the internet.
It connects to the red diagnostic connector located behind the left side panel.
  Another source for plug-in LED flasher unit. FLYTYM_imp 7 648 01-31-2022, 09:53 AM
  Cruise control DougsZ28_imp 12 975 07-27-2021, 05:14 PM
  McCruise Cruise Control cmc1891_imp 28 1,883 07-06-2021, 11:40 AM
Last Post: DougsZ28_imp
   Fuel line connection came undone and left me stranded! Riko_imp 33 3,695 12-04-2020, 12:29 PM
Last Post: 17-CB-002
  Indicator connection Chris Goldson_imp 4 392 04-21-2018, 07:09 PM
Last Post: Chris Goldson_imp
  left control wiring caddy425_imp 2 326 03-26-2018, 12:42 PM
Last Post: caddy425_imp
  Handlebar And Control Alignment Aka Tsubasa_imp 2 271 07-12-2017, 06:38 AM
  Idle Air Control Valve (IACV) dave 12 725 07-23-2016, 02:31 AM
Last Post: LongRanger_imp
   Oil Pressure Sending Unit Tap Ralph_imp 8 659 10-29-2015, 11:05 AM
Last Post: Ralph_imp
  "Headlight Unit" Replacement gmike_imp 2 266 09-04-2015, 12:42 PM
Last Post: gmike_imp
