Tire pressure
I just put new Michelin P R 3 tires on yesterday. When picking up the bike from the shop,I asked how much pressure did they put in. Tech stated 36 in rear 36 in front,his comment was when they warm up ,it will be 40psi. I thought 40 psi was cold pressure Am I mistaken .
I believe spec is 36F 42 R cold (however those are recommendations I run 38 front 40 rear cold)
Tire Pressure Spec is always at ambient "cold" temperature. Change your shock preload, not tire pressure. Pressure affects traction, grip, wear, handling, ... engineers figured that out. Hopefully not the engineers that did the gearing for the 2013-lol.
That's what I was thinking, this place is a express tire and lube bike shop.
34 front, 42 rear on the PR3's on my CB.
  low oil pressure light Garuda78_imp 16 1,080 02-29-2024, 04:09 PM
Last Post: Garuda78_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 870 10-09-2023, 07:51 AM
  low oil pressure light kaput norton1974_imp 11 988 03-28-2023, 08:58 AM
  Interesting article on tire pressure the Ferret 9 798 11-28-2021, 04:23 AM
Last Post: j3gq_imp
  Cold Weather & Tire Pressure 2017EX_imp 22 1,287 11-28-2019, 08:53 PM
Last Post: Cqrlm911_imp
  Catalytic converter back pressure? ChipBeck_imp 13 895 05-26-2019, 01:42 AM
Last Post: HondaJon_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 944 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  Rear Brake Intermittent Loss of Pressure beardyweirdy@me.com_imp 9 637 11-04-2017, 12:26 AM
Last Post: Dengie Boy_imp
  Tire pressure Sonnyboy_imp 4 423 10-23-2017, 04:51 AM
Last Post: kennyw
  Tire pressure glynb_imp 12 823 09-29-2017, 03:00 AM
