cycle computer issue
when the gas tank is nearing empty and the last bar flashes the display is supposed to allow/show miles to empty (MTE) and gallons left.
i have ran the gas that low 3 times.
the first time the display automatically switched.
the last 2 times it switched but displays no information on MTE or gallons left. it just shows a dash - .
anybody with similar experience?
not sure if there is a reset or something else i can try.
TIA.
What mode is the screen in? "Total", "A", "B"? Does MTE work/not work in all three or just total?
i usually ride with the screen on the instantaneous MPG.
when the last gas bar started flashing it automatically switched to MTE.
i can toggle through all other displays and they work/display correctly except the MTE and gallons left.
for trip a and trip b it gives: miles, MPG, and gallons used.
MTE and gallons left can only be toggled to when the last bar is flashing.
Hmm, this must only be a 2014 thing huh? I believe the 2013s just flash (no MTE).
try reconnecting the battery, it worked after I did that.
could be due to that, or could be working on its own
not sure about that, but worth a try
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 593 01-30-2026, 02:16 PM
Last Post: JRD
  Shifting issue Cormanus 31 2,564 05-15-2024, 12:59 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 488 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 303 06-29-2022, 04:37 AM
  Brake reservoir screw head issue satchit 72 5,945 04-24-2022, 11:55 PM
  Mechanical issue and hello again RickNRoll53_imp 8 694 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 394 11-27-2021, 07:11 AM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,317 07-19-2021, 08:28 AM
  starting issue jigs_imp 12 898 06-06-2021, 01:51 PM
Last Post: max
  Got an issue,anybody else? FLYTYM_imp 13 1,179 11-28-2020, 09:51 AM
