Got an issue,anybody else?
My bike has an issue with finding neutral when it's cold. The transmission easily goes into neutral but the indicator shows the FLASHING DASH and the bike won't start with the kickstand down. Once the bike warms up everything is fine. Could be a sticky neutral switch?
Without looking at the wiring diagram, it could be sticky. But you may want to check the connector for corrosion or proper seating first.
The green neutral light is operated by a ball-detent switch under the engine, and is very reliable. The LCD display with the flashing bars is controlled by the gear position switch under the countershaft sprocket cover. It is a rotary switch turned by a slot in the end of the shift drum.
As Lord Popgun says, it is likely connection or corrosion problem at its plug-in. However, another forum member had a similar problem, and found that the roll pin on the switch's rotating shaft had fallen out. In this case, it might be just loose, but ready to fall out. Easy to check, but be sure you note the pin's position, as the shaft can be rotated 180 degrees out of phase.
Nice call PD. I forgot about the member with the pin problem.
@peking
Really interesting for trouble-shooting, but...
any chance you could add a simple sketch or part# or sth of
- ball-detent switch
- countershaft sprocket cover
- the roll pin
It all sounds good, but when I am trying to locate this stuff in the service manual I get nowhere. I assume this means that I am simply not familiar enough with the pieces you mention. May be others have the same problem.
J3, here ya go: https://www.partsfish.com/oemparts/a/hon...rear-cover Item 14
See section 19 in the service manual for the switch. In the older 13/14 manual it is page 19-38. Will be in the same section in a newer manual.
(11-27-2020, 03:47 AM)pekingduck_imp Wrote: The green neutral light is operated by a ball-detent switch under the engine, and is very reliable. The LCD display with the flashing bars is controlled by the gear position switch under the countershaft sprocket cover. It is a rotary switch turned by a slot in the end of the shift drum.
I did have the kick stand off to shorten it awhile ago,I'll have to look at this when the bike comes apart for OPERATION FACELIFT.
I got this mixed up with the kick stand switch,is 14 in the diagram the neutral switch?
No. The neutral switch, for the starting interlock and lighting the N is here: https://www.partsfish.com/oemparts/a/hon.../crankcase
Item 8.
Oops, sorry, LP was there first with the parts diagrams. Wish I thought of it before I took my engine out and stripped it for some good pictures!
The shift drum and switch are actually from a different bike. The CB1100 is a bit different but works the same. Note that the roll pin is offset in the shaft to be sure it isn't installed 180 degrees out.
PD, does the 2014 have a neutral light AND the N on the panel?
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 577 01-30-2026, 02:16 PM
Last Post: JRD
  Shifting issue Cormanus 31 2,384 05-15-2024, 12:59 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 477 02-21-2023, 07:51 AM
  Fuel reserve display issue Banksy_imp 2 293 06-29-2022, 04:37 AM
  Brake reservoir screw head issue satchit 72 5,434 04-24-2022, 11:55 PM
  Mechanical issue and hello again RickNRoll53_imp 8 685 12-16-2021, 06:46 AM
  CB 900C Custom Spark Issue goatman64_imp 3 381 11-27-2021, 07:11 AM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,160 07-19-2021, 08:28 AM
  starting issue jigs_imp 12 842 06-06-2021, 01:51 PM
Last Post: max
  Safety issue to watch out for. LakeWylieJoe_imp 7 536 08-22-2020, 12:05 AM
Last Post: LakeWylieJoe_imp
