Threads: 16
Man I need the torque setting for the upper triple tree and stem nut.
I think the specs for the front wheel removal (axle pinch bolts, caliper bolts) are in the owners manual...
Anyone gots that info. ?
Much obliged.
Likes Given: 142
What year do you have? Some of the torque values are different.
Bottom pinch bolt: '13 44Nm or 32 ftlb. After '13 (thats how the manual says it). 39Nm or 29 ftlb
Fork bolt (the one around the preload adjuster) 22Nm or 16 ftlb.
Then tighten the top bridge pinch bolt: 23Nm or 17 ftlb (no separate years listed for that one.
Steering stem nut: 103Nm or 76 ftlbs.
Hope that helps. All out of chapter 12 of the 2013-2014 service manual
Threads: 16
It's a 13. Thanks muchly Mr. Popgun.
