Speed limiter
HI, I have just joined this forum in the hope of finding out a bit about a speed limiter on the CB1100 2014/15 bikes that I have read in a review article.
I am think of buying the 2015 deluxe model but am a bit hesitant because of the speed limiter. Is there a way to undo the speed limiter?
Thanks
Howdy and welcome to the forum. Ok couple things. First off there are no 2015s. Honda didnt release a 2015 model except in Japan. There are some left over 2014 stds but the dlx's appear to be gone. Not sure if there are any 2013s in dealer showrooms, but if there are they will be the non abs models.
The speed limiter is set at the Japanese National Speed Limit of 180 kph or 112 mph. There is a company in PA I believe that will reflash the ecu removing the speet limiter and the rev limiter in the lower 3 gears. i believe that runs about $375.
http://www.guhlmotors.com/
Don Guhl can reflash your ECU and the remove speed limiter and move the rev limits if desired. And other things that I can't remember.
His website says they are moving to a larger shop so be patient in trying to get hold of him. It is my understanding that he is not a big computer guy, so I would call. There are a number of forum members who have had their ECUs reflashed and discussed it on here. I haven't as, well, I'll probably never go that fast Smile
Ferret, KS is in Malaysia. Do they get the 2015?
Ahh did not notice that popgun. I don't think so. He mentioned getting a DLX (probably what confused me). I would also think Malaysia would get EXs and not DLXs. Wonder if they have a nat'l speed limit in Malaysia?
Welcome kslmerkon,
I've had the ecu refreshed and the rev limiter raised 500 rpm.
Plus minor tweaks to the mapping.
IMO, worth it Wink
(01-26-2016, 03:17 AM)The ferret_imp Wrote: Ahh did not notice that popgun. I don't think so. He mentioned getting a DLX (probably what confused me). I would also think Malaysia would get EXs and not DLXs. Wonder if they have a nat'l speed limit in Malaysia?
all the cb1100 in Malaysia are all grey import units. Honda motorcycle malaysia does not carry it officially. Since there is a multiple number of independent importers, some might be new and some are pre-owned units and it could come from all corners of the earth.
generally, from what i have noticed in recent years is that brand new cb1100ex/cb1100 units are from japan / asian countries with speed limiters. Malaysia has a 110km/h ( 68mp/h ) limit on the highways officially.
Thanks for the info Scooticus
Reflashing the ECU may be one solultion for
overcoming the speed limiter.
In Germany some drivers use a self-learning
Vmax-Modul SLVM-1.
It works for a speed open ride.
Wisedrum
New member. 24. Recently acquired a '13 CB1100A as a trade in to the dealer I work at. 3k on the clock, yoshimura full system, windshield, luggage rack, $4k. Speedo had to be replaced since the PO broke it. I'm hoping to remove the timing retard, and top speed limiter, but I'm curious to know if anyone tried to go thru Honda for a reflash authorization? I work at a Honda (and Suzuki, Kawasaki, Yamaha) dealership, so for the free 10 minutes on the phone to Honda tech-line, I figured it's worth a shot. I heard people had success in Europe going thru their dealers.
Dont think anyone on this forum has gone thru a dealer/american Hnda for a reflash and havent heard that route mentioned from any of our members from 21 countries. Worth a call for you I suppose then you can tell us for sure if it's possible pusuing. Personally I doubt that would happen. never know though.
How does one break a speedometer, did the PO say?
  CB1100 Idle speed instability problem ericlo69_imp 1,434 117,237 07-26-2026, 01:51 AM
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 845 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 518 02-13-2025, 06:25 AM
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,138 02-21-2023, 12:22 PM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,367 06-03-2022, 01:16 PM
  Speed bleeders Raceman_imp 21 1,480 12-14-2021, 04:30 AM
  Limiter Billie_imp 13 1,073 04-29-2021, 04:46 AM
Last Post: Billie_imp
  speed sensor output Lord Popgun 16 1,096 10-09-2020, 09:20 AM
  5 Speed, extra tooth Rogerdj_imp 2 307 09-12-2020, 08:01 PM
  RE: CB1100 Idle speed instability problem Lambchops_imp 52 3,298 07-09-2020, 08:06 AM
Last Post: SportsterDoc
