Electrical plug contact cleaning and maintenance
I'd like to do some preventative maintenance to prevent corrosion of metal electrical contacts in the 2P, 3P and 4P plug connectors for the various sensors including TPS, EOT, IACV, etc. I'm thinking, rightly or wrongly, that some of the low/high idle issues seen by some CB owners could be due to some corrosion on the leads in the plug connectors resulting in intermittent electrical connection problems to and from the ECU.
I'm thinking of unplugging the connector and using an electronics cleaner such as [url=https://www.amazon.com/CRC-5103-Quick-Electronic-Cleaner/dp/B000BXOGNI#Ask]this product from CRC to clean the contacts and then perhaps adding a bit of dielectric grease before reconnecting the plug.
Sound reasonable? If not, other suggestions for products and/or methods to use would be welcome.
That CRC stuff is a cleaner and works well. I use it a lot. Then I usually add CRC 2-26 http://www.homedepot.com/p/CRC-2-26-5-oz.../100398344
It protects, etc, and inhibits corrosion. You could use the dielectric grease, but unless called for, I usually don't like to goop up the connectors. But that works too.
I'm a big fan if dielectric grease.
When I restored my two vintage bikes I used dielectric grease in every electrical connection on new wiring harnesses.
99.9% of those connections have not been apart in 38 years combined (except for battery removal for winter storage) and both bikes and electrical systems run perfectly.
Deoxit cleaner is the product that us BMW old motorcycle riders swear by. And then the dielectric grease. No need to apply so much that it oozes out. Just cover the pins.
(01-21-2017, 01:11 AM)Elipten_imp Wrote: Deoxit cleaner is the product that us BMW old motorcycle riders swear by. And then the dielectric grease. No need to apply so much that it oozes out. Just cover the pins.
Agree, a little does the job and no need to make a big mess.
I use "tuner" cleaner and contact burnisers to restore old connectors and then apply a small amount of dielectric grease. Never has failed me.
Thanks for the feedback and advice guys. Thumbs Up
  NGK spark plug options Jonnyteabag_imp 6 644 08-05-2026, 11:35 PM
Last Post: JRD
  Advice please--maintenance on new to me CB LucienLeFranc 11 806 06-24-2026, 01:34 PM
  Booster Plug on an RS TheLegend 6 493 04-22-2026, 06:31 AM
Last Post: TheLegend
  Cleaning exhaust headers. meowguy_imp 26 2,388 08-12-2025, 03:13 PM
  Basic Maintenance: Daily Check rdprdp01 17 1,412 03-01-2025, 02:52 AM
  What is this plug? MagnaRider 7 707 02-13-2025, 03:39 AM
Last Post: MagnaRider
   Light problems/electrical Dude_imp 6 597 09-13-2023, 07:21 PM
Last Post: Dude_imp
  Spark plug socket. Jgarciajr40_imp 5 571 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plug caps alexzanutto_imp 3 417 01-29-2023, 06:21 AM
Last Post: artashline_imp
  Winter Battery Maintenance Wagonpeddler_imp 27 2,218 10-18-2022, 01:55 AM
