 Light problems/electrical
Hey guys I have never had to mess with an electrical issue before on a vehicle and I am needing some guidance on where to troubleshoot first. Bike has 40,000 miles and is my daily rider. Great bike!
So the issue was initially with the headlight, it would turn off every few minutes or so while riding. I have changed the headlight bulb and the issue is still present. Most times when I turn the bike over the headlight is on.
Now I'm having issues with the turn signals. None of them work at all and they don't flicker or turn on or anything when starting the bike, they are currently completely inop. Could this just be a fuse issue or a ground wire issue? I will be getting into the bike over the next couple of days when I have time off.
Also, the computer/clock resets to "1:00" after the bike is turned off for more than a couple of minutes, all other gauges appear to be working normally.
The tail light functions how it is supposed to without any problems. I am a noob at this and just looking for some guidance/help. Thank you
Hmmm, my first guess is a weak battery.
My second, a weak alternator or charging system.
check the grounds and clean them and battery connections and the main fuse make sure its clean too
After doing what 1973 said, try a new battery as it sounds like he problem.
Agree with 1973 and LP say - check grounds and battery connection. The circuit that keeps the clock time also keeps the trip odometer reading on after the key is turned off. Do you lose the trip odo reading too?
The 3 areas of electrical problems are:
connections
connections
connections
The erratic, intermittent (now constant) problems suggest poor connections.
Battery failure would manifest itself as non-starting.
Are there any electrical accessories or mods?
(09-13-2023, 08:21 AM)pekingduck_imp Wrote: Agree with 1973 and LP say - check grounds and battery connection. The circuit that keeps the clock time also keeps the trip odometer reading on after the key is turned off. Do you lose the trip odo reading too?
connections
connections
connections
No electrical accessories or mods. The trip odo is always correct, it's just the clock that resets when parked. I'll check the battery when I get home. Thank you guys
Well, the blinkers turned out to be a bad fuse. Tightened the battery terminals down, they appear to be okay, didn't check with a meter though.
Still having the headlight go off intermittently for a few minutes at a time and the clock resetting to 1:00.
Edit: just found out there is a different location for the main fuse, I will check that later today.
  Delkevic 9" Oval Install Problems. jbird06_imp 4 457 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  Looking for OEM electrical terminals/connectors. FLYTYM_imp 2 296 07-14-2021, 01:13 AM
Last Post: FLYTYM_imp
  Electrical problem maybe? Cormanus 37 2,338 05-25-2020, 08:19 AM
   Engine light Blinking tory_imp 25 1,699 12-04-2019, 10:38 PM
  electrical power pick up andyoz_imp 6 635 11-19-2019, 10:17 AM
  Rear Wheel problems Sfomoto_imp 30 1,791 01-05-2019, 11:15 PM
  running light and brake light Ennsync_imp 3 411 01-02-2019, 11:24 PM
   H4 Head light Bulb Question Ennsync_imp 36 2,445 12-30-2018, 01:48 PM
  Fuel Pump problems ? sharkyo4_imp 11 762 07-06-2018, 10:02 AM
  Electrical Gremlin - Clock/Trip Reset & No Blinkers johnf514_imp 10 805 03-23-2018, 04:16 AM
Last Post: max
