What is this plug?
Noticed this plug was unplugged on my CB, with no apparent plug to plug into it.
Underneath the right side side cover. Any ideas what this is? If its the OBD plugin I feel like it should atleast be covered.
The heated grips T in that area. Are they?
That is your o2 Sensor that connects inside of the clear boot. It might be bypassed.
http://cb1100forum.com/forum/showthread.php?tid=6988
What are the wire colors? That will tell us.
(02-10-2025, 12:06 PM)pekingduck_imp Wrote: What are the wire colors? That will tell us.
I will investigate tonight on wire coloring!
I had a thought it was the O2 sensor but its still in and not plugged off. Thanks!
I believe the blue connector (2 wires) in that boot is the rear wheel speed sensor.
The OBD is a red cap under the left side cover.
Oops, my wiring diagram is a 2013 model.
Confirmed the O2 sensor. This weekend I'll remove the sensor itself and plug the bung up cuz why not.
Tempted to rehook it up just to see how noticeable the difference is... but probably not lol
  NGK spark plug options Jonnyteabag_imp 6 637 08-05-2026, 11:35 PM
Last Post: JRD
  Booster Plug on an RS TheLegend 6 489 04-22-2026, 06:31 AM
Last Post: TheLegend
  Spark plug socket. Jgarciajr40_imp 5 567 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plug caps alexzanutto_imp 3 406 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 786 10-08-2022, 12:22 PM
  Another source for plug-in LED flasher unit. FLYTYM_imp 7 632 01-31-2022, 09:53 AM
  Oil Drain Plug Washer Size Tev62 14 1,070 11-18-2020, 06:29 PM
Last Post: jtopiso_imp
  Front fork plug/bolts. FLYTYM_imp 1 251 04-12-2019, 09:53 PM
  Question about missing plug or cover. tate_imp 6 537 01-08-2018, 06:51 AM
Last Post: tate_imp
  Spark Plug Replacement every 8,000mi Rolls_imp 34 2,432 08-11-2017, 03:51 PM
Last Post: Randy B
