Paint Flaking - Cylinders
My cylinders are in a bit of a mess!
Have a look at these pics....
[Image: c9d738f8105a2a195fb0a3e25b948ae7.jpg]
[Image: c6e665720414b83b87565eed7f74d7d2.jpg]
[Image: 990e0f3e51d0f1e7079616195d92a079.jpg]
[Image: 29be6a934161c37b1afc1db4a324ba52.jpg]
It was new in Aug 2014, so its mid way thru its 3rd winter. It lives outside and I ride all year.
I have a hose right by where I park my bike and always wash her down if she's been out in the wet. Extra thoroughly in winter.
It's just the cylinders really, the cases and Cylinder heads all seem to be holding up quite well. I had the spark plug manifolds re-placed under warranty for the same problem.
I understand that things age but I'm a little disappointed with the quality of the paint. Is that un-reasonable?
I'm out of warranty by 6 months now, so it's all academic really.
I was thinking of painting them in situ with a HT Black satin paint. Not ideal but it's got to be better than them looking all scabby like that. Especially as the rest of the bike looks so nice....
(02-12-2017, 02:54 AM)beardyweirdy@me.com_imp Wrote: My cylinders are in a bit of a mess!
"in situ" ?
Are you thinking about using a wire brush to remove the flakey stuff, and then using a brush to paint the cylinders on the assembled bike? That might be a little tricky.
Removing the cylinders and having them bead blasted and spray painted would be better, but expensive and time consuming.
Either way the motor would look better all aluminum. Just compare a picture of the 2014 Deluxe versus the 2017 EX. Having the motor all aluminum makes it stand out as the centerpiece of the motorcycle.
I know there is heat resistant aluminum spray paint, because I painted the steel cylinders of my 1966 Yamaha 305 with it when they rusted.
That SUCKS !
Ride it.
Repeat.
Nothing lasts forever !
Ride it some more.
I'm amazed that it's 2 1/2 years old and only 6 months out of warranty. I wonder why the U.S. only gets a 1 year warranty and the rest of the world gets a 2 year warranty. BTW mine is almost 3 years old, 28,000+ miles but never needed the warranty.
The painting of the cylinders doesn't look good, I agree.
Have the same cosmetic problem wirh my 2013 CB and it arose the first time very early.
My Honda and I live with it ever since. Some owners in Germany have the problem, but only with the early version as I own.
All I could find out is, that something with the grounding color for the finishing one is not as good as it should be. It let oxidation happen. Sometimes I do some brush painting, mostly I use Balistol to keep it a bit oily as a kind of prevention. My CB also lives outside....
Wisedrum
(02-12-2017, 03:27 AM)kballowe_imp Wrote: That SUCKS !
Ride it.
Repeat.
Ride it some more.
I agree. I keep mine clean and maintained... but it's definitely not new anymore... just noticed some rust around headlight ring.. just over 10k on clock and 18 months old... still very happy. Rust on oil lines.., my garage was built in 1935. I keep the bike covered inside but high humidity... I think I'm going for a ride.
Ride it.
Repeat.
Ride it some more.
Indeed, that's why I ride it every day and I guess that's why the paintwork looks so bad.
I'm new to new bikes and I guess it is slightly un-reasonable to expect the paint to stay on the barrels for 2 1/2 years.
Thinking about a brush paint, just on the cylinders. My old Lightning had black Barrels and it looked quite cool. If I make an arse of it then I'll strip down the top end and have them blasted.
I'll post some pics when I freshen it up for Spring...
I'm kind of surprised that the fins are painted. Has it always been that way with Honda's air cooled fours?
It's doesn't seem to be a common problem. I'm sure it has to do with the outside elements that it's exposed to. I live and ride near the ocean all the time all year round and I don't have any issues on my 2014 with the finish at all other than the horn bracket has a little oxidation. I do wash it regularly and it is garaged. Do you cover it? Do you ride near salt water? Could be from lots of external element factors where you live. I don't know what would cause it.
Sent from my SM-T350 using Tapatalk
I know my 2014 has a different finish but still that seems quite extreme.
"in situ" ?
"in situ" ?
i just had a look at the new2017 EX and I don't like the black barrels.
Your right, it looks much better with an all silver Engine. Although polishing the barrels will be hassle.
May just clean up and have done... Thanks, glad you joined that out. I hadn't realised the new EX already had what I was thinking of doing to mine.
(02-12-2017, 10:20 AM)uscgmac_imp Wrote: It's doesn't seem to be a common problem. I'm sure it has to do with the outside elements that it's exposed to. I live and ride near the ocean all the time all year round and I don't have any issues on my 2014 with the finish at all other than the horn bracket has a little oxidation. I do wash it regularly and it is garaged. Do you cover it? Do you ride near salt water? Could be from lots of external element factors where you live. I don't know what would cause it.
I used to cover it but I thought the condensation was worse than letting it dry out, so now I leave it uncovered.
(02-12-2017, 10:05 AM)Stichill_imp Wrote: I'm kind of surprised that the fins are painted. Has it always been that way with Honda's air cooled fours?
I don't think so. I'm sure my 400/4's had bare fins. Not certain tho.
Are the barrels painted on the USA models?
  Can I paint ABS Pulsers ? HondaLou 6 382 06-26-2026, 06:15 AM
Last Post: HondaLou
  Black Frame Paint spechg 12 1,030 06-24-2026, 08:12 PM
Last Post: HondaLou
  Stock Cylinders dave 5 864 10-14-2025, 10:41 AM
  Engine Cover Paint deltamark 9 760 09-05-2023, 06:22 AM
  Oiling cylinders for winter storage? Searcher_imp 5 534 01-26-2023, 08:33 AM
Last Post: ichiban_imp
  Anybody paint their wheels black on a '13? boynton6spd_imp 2 329 06-14-2021, 11:08 PM
Last Post: MrBob_imp
  Engine Paint shahyaan_imp 21 1,567 11-14-2020, 01:34 AM
Last Post: Jfro5687_imp
  Paint dave 5 447 05-09-2020, 03:59 AM
  Paint maintenance Cormanus 17 1,176 04-13-2020, 01:19 PM
  Shock spring paint HBFL_imp 6 473 10-30-2018, 05:21 AM
Last Post: HBFL_imp
