10-29-2018, 05:05 AM
I'd like to see my 13's shock springs black like the 14. I'm wondering how rattle can paint would hold up under the flex, any thoughts?
Shock spring paint
10-29-2018, 06:31 AM
I would powdercoat them.
10-29-2018, 07:01 AM
You'd have to "rough them up a bit" first. And use a flexible paint. What about Plasti Dip?
10-29-2018, 02:46 PM
Paint would not hold up well. They need to be dipped in flexible material. Your cheapest option is probably to buy those black springs from Honda.
Chip
10-29-2018, 05:46 PM
HBFL, I tried to reply to your PM but it is disabled on your end. But to answer your question, the paint on my Kayaba shocks held up fine. It was a normal gloss black spray can paint, not powder coated. I've painted springs for years, going back to the Girling days, and never had a problem. They do not have to be painted with any special paint.
The difference is that I took the springs off to do it, which you won't be able to do on your shocks - they are not designed to be taken apart. The chrome cover would have to be compressed about an inch before the shaft's jam nut is exposed. Re-assembly would be the hard part as you also have to hold the shaft firmly. The 2014 shock springs are not available separately from Honda, so you might put a wanted ad for take-off shocks - many members have replaced theirs. Most powdercoaters like to run their ovens around 400 degrees F so the paint flows smoothly and gives a nice gloss. Most of what they are coating are furniture and gates, nothing critical. Don't know how well they regulate the ovens or how long they are baked, but I don't like to powdercoat springs as they will lose their temper from excessive heat. I think their threshold is closer to 350F. I had a bicycle frame with brazed lugs come out of the powdercoater's oven with loose lugs because the filler had melted away. That oven was way too hot.
10-29-2018, 07:44 PM
On this link there is a range of opinions wether if it's a good or a bad idea to powdre coat a spring:
https://advrider.com/f/threads/can-shock...ed.865892/ https://www.caferacer.net/forum/technica...rings.html It's true that most performance springs manufacturers power cat theirs, but they know their process (temp/time) and materials, and your "local coater" probably won't. So I'd stay on the safe side and not do it. I don't think it would affect the ride rate (stiffness), but the strength/hardness could be affected, amd this would have a direct impact on the fatigue life of the spring (it can creep or crack under cyclic loading).
10-30-2018, 05:21 AM
Thanks for the feedback all, and thanks Pekingduck re: my IM, I fixed that. Good to hear your paint held up. If I proceed with paint or plasti dip, There is so much space between the 13's coils that I can wrap everything up with tape.
But most likely I won't do anything. It's just cosmetic preferences, but so are most of my mods. |
« Next Oldest | Next Newest »
| Can I paint ABS Pulsers ? | HondaLou | 6 | 378 |
06-26-2026, 06:15 AM Last Post: HondaLou |
| Black Frame Paint | spechg | 12 | 1,028 |
06-24-2026, 08:12 PM Last Post: HondaLou |
| Front Fork spring rate? | sprint | 0 | 257 |
05-09-2025, 12:23 PM Last Post: sprint |
| Another shock thread, but SHOWA | JLEECB | 17 | 1,608 |
02-09-2025, 11:23 PM Last Post: Tev62 |
| Engine Cover Paint | deltamark | 9 | 759 |
09-05-2023, 06:22 AM Last Post: Cormanus |
| Spring Tool | Houtman_imp | 32 | 2,127 |
10-17-2021, 12:41 PM Last Post: PowerDubs_imp |
| Rear shock adjustment for pillion and bags | alexzanutto_imp | 6 | 604 |
07-20-2021, 07:49 AM Last Post: Tev62 |
| Anybody paint their wheels black on a '13? | boynton6spd_imp | 2 | 327 |
06-14-2021, 11:08 PM Last Post: MrBob_imp |
| Engine Paint | shahyaan_imp | 21 | 1,564 |
11-14-2020, 01:34 AM Last Post: Jfro5687_imp |
| Paint | dave | 5 | 445 |
05-09-2020, 03:59 AM Last Post: dave |
