Engine Paint
Heya
I just bought the CB1100RS used and noticed a few chips on the engine fins. I want to fill them in before corrosion lifts of the paint around it.
The engine is a dark grey colour. Any ideas as to the closest paint match to fill these in?
I have a similar issue on my bike as well. Its CB1100EX from 2015. Past owner lived close to the sea. Dont know if this along with regular karchers chipped of the paint.
I wash my bike with a regular garden hose and dish washing liquid.
What kind of paint should I use to recoat this area ? Any particular method ? Or precaution ?[Image: ee2c8c5808b814607fcee48c559f740b.jpg]
Envoyé de mon SM-G930F en utilisant Tapatalk
Yours looks to be the lighter engine colour which might just be lacquer based on the looks around this forum
shahyaan, welcome to the forum. Back in 2013-14 when the CB1100 first went to the UK, there was an UK-based CB1100 forum. It died from lack of interest, although I think that was a lack of interest in the forum rather than the CB1100.
Anyway, there were many reports on that forum of what members called 'fin rot' which seemed to be more of a problem in the UK than the US. Maybe it was because the early bikes had the paler coloured engine of N4RN's bike. We have that colour in Australia and my bike has many a chip on the engine; mostly, I suspect, because I ride it more than I maintain it and flying rocks and debris will have their way.
Search is your friend on this forum. Somewhere there is a post by Pterodactyl on restoring a scratched engine part. I thought it was [url=http://cb1100forum.com/forum/showthread.php?tid=2802] this thread , but alas it was not. I can't find it, but you could search. As I recall, he painted the part with a high-temperature resistant paint and baked it in the oven for a while to cure it.
Hi Cormanus
Thanks for the reply. Been searching around for a while just couldn’t find anything specially for the darker engine. I may have come across that thread or a reference to it at least in my searches.
Just need something to touch up the fin edges which are as you say most likely chipped from debris. I don’t think it’s the rot as is only on the leading edges on the outer fins
I should have been clearer that there was no rot as such. It was just the term used to describe it, although some of the cases seemed quite extensive.
I guess you just need a matching enamel paint than can sustain the temperatures reached by the engine. I've had a reasonable hunt and I can't find Pterodactyl's post. Maybe he just told me about it over a beer. Anyway, I'm sure one of the things he had to do was to cure the paint at a high temperature and he did it in the oven. Whether just running the engine for a while will do the job, I don't know.
That makes sense. Was thinking never heard of rot in paint. I might pop to the Honda dealer here and see if they have the paint pens. It’s such a small area. Wouldn’t mind a can if I could get the right colour.
Interesting that the exposed material is brown in colour.
Nevertheless, isn't the cylinder head cast aluminum? If you take a small metal file, can you remove the brown material to expose new aluminum? I realize new aluminum will oxidize immediately when exposed to air, however, it should settle down to a grey or whitish-grey finish - which should stop oxidizing. I do not know if further reactions occurs due to exposure to a salt-water environment. Is that the reason it is called "rot"?
In terms of high heat paint, silver-grey spray can high-heat paint has been readily available for decades with some tolerating the 1400F temperature range. That should be more than enough margin.
I use high heat paint to restore the engine painting of my 2013 CB. But it doesn't solve the problem of a bad primer Honda used with this model. My attempt to better the former good but after a while vanishing because oxidated ugly outlook of the engine is not lasting. I have to redo it over and over again once it looks bad again. It is a shame that Honda wasn't able to do a better work with the finish.
Thanks for the reply guys. I just hope it doesn’t get too bad. What a shame that it’s an issue
  Can I paint ABS Pulsers ? HondaLou 6 377 06-26-2026, 06:15 AM
Last Post: HondaLou
  Black Frame Paint spechg 12 1,018 06-24-2026, 08:12 PM
Last Post: HondaLou
  Engine Cover Paint deltamark 9 754 09-05-2023, 06:22 AM
  Anybody paint their wheels black on a '13? boynton6spd_imp 2 323 06-14-2021, 11:08 PM
Last Post: MrBob_imp
  Paint dave 5 442 05-09-2020, 03:59 AM
  Paint maintenance Cormanus 17 1,155 04-13-2020, 01:19 PM
  Location of Engine Number on Engine? cb1100_dude_imp 2 323 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  Shock spring paint HBFL_imp 6 464 10-30-2018, 05:21 AM
Last Post: HBFL_imp
  Paint chip advice QimmiQ_imp 6 585 10-13-2017, 05:03 AM
Last Post: skidmarkart_imp
  Paint Flaking - Cylinders beardyweirdy@me.com_imp 31 3,082 03-30-2017, 12:53 PM
Last Post: jimgl3_imp
