Oiling cylinders for winter storage?
I can crank the engine without starting if I hold the throttle fully open while pressing the starter button. Will this coat the cylinders with oil for winter storage? Is it a good idea to coat cylinders with oil for long term storage? Removing spark plugs to do this through the hole seems like a lot of work.
Just leave it alone. It will be fine.
Depends on where it's being stored. I have a pretty dry garage under the house so I don't do it. If you are stuck with a damp environment and a long time for storage (very possible in Pitt) then you might coat it. just my ,02. TM
For a year or more storage, I would drip some drops into each cylinder and rotate the crankshaft.
I used to do that for a single seasonal storage, but stopped because I found myself riding the machine during the season.
We used to do that on watercraft, but not on the bikes. The watercraft have water boxes as part of the exhaust that are never fully empty. Figure a motor with an exhaust valve open to the wet water box and sitting for a period of time was known for rusting motor internals.
IMHO- Unless you store the bike in a really damp environment or for a REALLY long time....as in YEARS, I wouldn't bother fogging.
This practice is more prevalent in lawn care and power equipment Honda engines. You only want to be doing oil injection into a motorcycle cylinder if plan not to turn the engine over for years, it gives the piston rings a fighting chance not to stick and the piston skirt to drag on start-up.
(12-03-2022, 03:46 AM)DrewNJ_imp Wrote: We used to do that on watercraft, but not on the bikes. The watercraft have water boxes as part of the exhaust that are never fully empty. Figure a motor with an exhaust valve open to the wet water box and sitting for a period of time was known for rusting motor internals.
Spot on!
  Stock Cylinders dave 5 877 10-14-2025, 10:41 AM
  Frequency of chain oiling? Rebel73_imp 48 3,528 09-28-2023, 05:55 AM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,173 10-18-2022, 01:55 AM
  (End of) Winter Storage Wagonpeddler_imp 26 1,909 04-04-2022, 01:18 PM
Last Post: michael1954
  Oil change before/after winter? HikerToo_imp 11 808 02-09-2019, 05:08 AM
  Winter Bike Cleaning emptysea 27 1,841 03-07-2018, 11:38 AM
  Paint Flaking - Cylinders beardyweirdy@me.com_imp 31 3,104 03-30-2017, 12:53 PM
Last Post: jimgl3_imp
  Oiling chain 1100rider_imp 57 5,764 07-29-2016, 05:21 AM
Last Post: flynrider
  Hauled bike out of storage wont start. Oboro_imp 34 1,818 05-17-2016, 10:31 AM
Last Post: quail_imp
  Lean cylinders? mattmcuomo@yahoo.com 8 575 01-18-2016, 12:06 PM
Last Post: kmoney_imp
