Can I paint ABS Pulsers ?
My ABS Pulser on front and rear wheels were covered in rust.  I carefully sanded at 500 grit and some fine steel wool.
My question is if I can put a thin clear coat of paint on these to keep from rusting again?
Hoping the actual sensor will still work with a coat of paint on them.
Thanks for your help.
Attached Files Thumbnail(s)
If you hit a small part of it with clear and a magnet still sticks to that spot, chances are it will be fine. That’s my semi-educated guess having done so with the ABS tone ring on a car.
I may be wrong but isn't that the speed sensor?
'84 Honda Magna VF700 (Gone, but not forgotten)
'06 Yamaha VStar Classic 1100
'14 Honda CB1100 Std
Speed sensor is on the rear wheel, and if I'm correct, also serves as the rear ABS sensor. The sensor on the front is ABS. That's why I thought my '13 had "Rear only ABS" till I was set straight on it.
(06-24-2026, 09:54 PM)Gone in 60 Wrote: If you hit a small part of it with clear and a magnet still sticks to that spot, chances are it will be fine. That’s my semi-educated guess having done so with the ABS tone ring on a car.
Hondalou. If you try this repair, can you please inform the forum if it works?
IMHO silver metalic paint would give you much better effect than any clear coat..
(06-25-2026, 06:36 AM)MagnaRider Wrote: I may be wrong but isn't that the speed sensor?
The front is an ABS.
The rear serves dual function, ABS and WSS/VSS.
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Thank you everyone.  I'm going to remove it from the wheel, clean it up some more then apply a metallic or clear paint.  Will test the magnet/sensor on it and will post results after I get everything back together again.  May take another month or so, as I am rebuilding/painting the entire front end and replacing brake shoes, tires, fork seals, and cleaning up the electronic connections which had some corrosion in them from the Florida Gulf location.
Good idea - will test afterwards.
  Black Frame Paint spechg 12 1,018 06-24-2026, 08:12 PM
Last Post: HondaLou
  Engine Cover Paint deltamark 9 754 09-05-2023, 06:22 AM
  Anybody paint their wheels black on a '13? boynton6spd_imp 2 323 06-14-2021, 11:08 PM
Last Post: MrBob_imp
  Engine Paint shahyaan_imp 21 1,563 11-14-2020, 01:34 AM
Last Post: Jfro5687_imp
  Paint dave 5 442 05-09-2020, 03:59 AM
  Paint maintenance Cormanus 17 1,155 04-13-2020, 01:19 PM
  Shock spring paint HBFL_imp 6 464 10-30-2018, 05:21 AM
Last Post: HBFL_imp
  Paint chip advice QimmiQ_imp 6 585 10-13-2017, 05:03 AM
Last Post: skidmarkart_imp
  Paint Flaking - Cylinders beardyweirdy@me.com_imp 31 3,082 03-30-2017, 12:53 PM
Last Post: jimgl3_imp
  Engine Paint zippooriginal_imp 4 440 12-26-2016, 10:55 AM
Last Post: Rolls_imp
