Stock Cylinders
Can anyone tell me if our CB1100 cylinder bores are hard chrome (Nikasil) plated ?
Nikasil is a proprietary process that is considered a surface plating.  The process Honda uses is a deeply impregnated hardness process that allows for a single 0.25 mm overbore.  It may be their own process, as it has been used in their bikes and cars for many years.
There is no iron liner as on older air-cooled models, heat absorption/dissipation is crucial, and iron is a poorer conductor, and there is less complete contact between cylinder and liner.
(10-13-2025, 12:44 PM)pekingduck Wrote: Nikasil is a proprietary process that is considered a surface plating.  The process Honda uses is a deeply impregnated hardness process that allows for a single 0.25 mm overbore.  It may be their own process, as it has been used in their bikes and cars for many years.
Thanks pekingduck. Does Honda use the Fiber Reinforced Metal process on the CB1100 cylinders, or the thermal spray coating (Nikasil by trade name)?
It's not Nikasil, which is not borable - it's impregnated deep into the aluminum deep enough to bore it 0.25mm.  It's not a spray coating.
So, about how many miles does one get before the rings have worn through the aluminum cylinder bores and a new set is required?
thanks,
tdbru
(10-14-2025, 09:58 AM)tdbru Wrote: So, about how many miles does one get before the rings have worn through the aluminum cylinder bores and a new set is required?
thanks,
tdbru
This is the same process Honda uses on their cars.  Rings are the same high quality. Machining is so precise, pistons and rings perfectly fit the bores. Cylinder walls will wear very little.
So maybe 125-150+k miles before you have to even think about it.  And likely a new set of original rings will take it to 200k.
Remember having to keep engine speeds low on new bike break-in? New materials/machining techniques have made that unnecessary.
  How much do stock pistons weigh? jikemenkins 4 636 04-28-2025, 10:06 PM
Last Post: Whoops
  Oiling cylinders for winter storage? Searcher_imp 5 531 01-26-2023, 08:33 AM
Last Post: ichiban_imp
  Stock handlebar measurements misterprofessionality 5 555 04-12-2022, 05:47 AM
  Stock Suspension Adjustment riggies_imp 28 2,049 10-16-2019, 02:08 PM
Last Post: jdvalero_imp
  Handlebars - Back to Stock ishouldbuyatacotruck_imp 17 1,576 08-22-2019, 06:44 AM
Last Post: ishouldbuyatacotruck_imp
  stock tool kit (if you can call it that) 12cb96vfr_imp 11 888 02-09-2019, 02:28 AM
  Stock header weight PowerDubs_imp 6 501 08-25-2018, 09:56 AM
  Back to Stock Muffler beardyweirdy@me.com_imp 14 913 06-18-2018, 11:27 AM
  Paint Flaking - Cylinders beardyweirdy@me.com_imp 31 3,087 03-30-2017, 12:53 PM
Last Post: jimgl3_imp
  Lean cylinders? mattmcuomo@yahoo.com 8 566 01-18-2016, 12:06 PM
Last Post: kmoney_imp
