bar end mounts removal
have after market bar end mirrors and cannot get the mounts out after taking the bar end weights out does anyone have an answer or possibly explain how they come out thanks my fellow badseed riders
(02-03-2017, 06:30 AM)p32077_imp Wrote: have after market bar end mirrors and cannot get the mounts out after taking the bar end weights out does anyone have an answer or possibly explain how they come out thanks my fellow badseed riders
If you are talking about what appears to be the threaded insert inside the handle bar I don't believe it comes out but is welded in place.
After you take off the bar ends you must remove the weight. See item 9 on the fiche : http://www.partzilla.com/parts/search/Ho...parts.html
It is held in with items 11 and 12. 12 will/may be destroyed when you remove the weight. The items hold it in pretty dang good.
How to get it out? When I got a throttle control kit for my ST it came with a long screw, a washer, and a basically piece of pipe an inch or two long. Hold pipe on handlebar end. Put washer on end of pipe. Put screw through washer and pipe into the weight. Then use the screw to pull the weight out as far as you can, then use your hands or pliers. Not hard really, but the clip, item 12 got ruined. New new rubber parts and the clip are cheap.
I would think you could find a socket that would fit and do the job.
I wonder if the CB1100 uses the same bar end weight clips as the CB500. If so, there is an easy way of removing them by rolling back the grips, pushing the clip tangs in, and drawing the weights out.
[Image: 02e1fc8f1c9bac7e8f35d84110768a22.jpeg]
It is fully explained in this [url=http://www.cb500x.com/index.php/topic,3834.0.html]BAR END WEIGHT thread on the CB500X Forum.
The parts numbers for the clips are not the same, but assemblies are built the same. Weight, 2 rubber parts, and a clip. Might work.
I just looked in the service manual and it says to do pretty much what your pic shows.
Straighten the retainer tab with a screwdriver or punch
Temporarily install the handlebar weight (the end weight they are talking about) and screw, then remove the inner weight while turning the handlebar weight.
Note: Apply lubricant spray through the tab locking hole for easy removal.
It also says to use a new retainer when reinstalling.
anyone know if bar end weight type cruise control work on our bike? like this one? https://www.denniskirk.com/kuryakyn/mech...904421.sku
A crowd called Kaoko made a similar one which I'm pretty sure fitted the CB1100, although no-one on the forum seems to have had one on their CB. Their web site, http://www.kaoko.com/ is not responding, but Revzilla appears to stock them.
thanks! $141 for a throttle lock... nah.
yes exactly like the 500x as that is the bars i used. puill off the grips and throttle and push in in the small holes top and bottom
not real hard to do ther is just a little catch in there
Jimgl3, get you one of these: http://www.2wheelride.com/GoCruise_throt...trol2.html
They work and are not expensive. A number of members have them. I have one also, but keep it as a spare in case my Throttlemiester (on the ST) or BrakeAway (on the CB) gives me problems.
  Valve Adjustment and Camshaft Removal dave 5 625 03-21-2026, 04:49 PM
  Left side cover removal jeffmazz_imp 24 2,120 07-09-2025, 03:37 PM
Last Post: bflint
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 5,965 07-25-2022, 06:54 AM
  Easy bar end weight removal brian10x_imp 6 620 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Air box removal ACE_IRA_imp 23 1,645 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
  Fuel Tank Removal Gabby_imp 11 933 06-19-2020, 10:54 AM
  Canister removal Feelergaugephil_imp 2 315 10-11-2019, 10:59 PM
  Rubber Spacers Handlebar Mounts jermo47_imp 8 571 05-22-2019, 12:58 AM
Last Post: jermo47_imp
  Handy Cheat Sheet for Maintenance and Wheel removal on my 2017 17-CB-002 12 860 04-17-2019, 12:40 AM
Last Post: ArbitraryThawt_imp
  tire removal jdgrego1_imp 27 1,765 11-15-2018, 07:18 AM
Last Post: jdgrego1_imp
